MGTM0 Interface only in Admin VDC in Nexus 7010
lomonaco
   Hi guys,
      I created two new VDCs in a Nexus 7010 (NX-OS 6.2.6) and I can see the MGTM0 interface only in the Admin VDC
      I wanted to see the MGTM0 in all VDCs.
    Does someone get this problem too ?
    My Best Regards,
    Andre Gustavo Lomonaco
Reza Sharifi
Each VDC should have its own mgmt0 interface. Try recreating the VDCs again.
 Hi Reza,
      Thanks for your reply.
      If the user run the setup wizard, the interface mgtm0 will be created in VDC.
      If the user don't run the setup wizard, the interface mgtm0 will not be created and you will need
      to only use the interface mgtm 0 command to create the interface.
      Thanks a lot
Interesting, by setup wizard you mean gui? I have always used the cli to create VDCs and never had any issue with mgmt0 being created.
