Need configuration of 1720 using DLSw "LLC2/QLLC Conversion" over ISDN.
g.quintin
I need a configuration about DLSw.
The remote 1720 converts LLC2 -> QLLC (X25) over ISDN dial on demand connection to the central site.
The central site accept the X25 call to forward it to an ES/9000 IBM.
Thank you for your help, if you have any congif.
This is my first installation but not the more easy, isn't it?
skoretsk
There are many configuration examples for DLSw+ X.25 configuration on Cisco CCO - you'll find them at this URL:
http://www.cisco.com/warp/public/488/qllc_index.html
You'll find an excellent example of DLSw+ ISDN DDR at this URL:
http://www.cisco.com/warp/public/697/dlswdodisdn.html
Regards, Steve
