Nexus 1000v Layer 3 mode Primary and Secondary VSM communication problem.
egorospe07
Beginner
Beginner
I have a HA Pair setup and everything works fine when both my primary and secondary VSMs are on the same host.  However,   when I migrate either of my VSMs to another host  Communication is lost.
Both hosts are on the same subnet and is able to ping each other.  Subnet is 10.20.0.0/16
Any help would be much appreciated..
I also receive this message on my primary VSM:
%VEM_MGR-SLOT5-1-VEM_SYSLOG_ALERT: sfswitchdata : L3 Control and System VLAN configurations not applied on vethernet port. VMware Port[83886108] DVPortGroup[dvportgroup-36347]. L3 Control can be applied only on VMKernel port.
Show module on my VSM produces this output:
Mod  Ports  Module-Type                       Model               Status
1    0      Virtual Supervisor Module         Nexus1000V          active *
2    0      Virtual Supervisor Module                             powered-up
3    248    Virtual Ethernet Module           NA                  ok
4    248    Virtual Ethernet Module           NA                  ok
5    248    Virtual Ethernet Module           NA                  ok
my uplink port profile:
port-profile system-uplinks
type: Ethernet
description: uplinks to management nics p1,2 (v0,1)
status: enabled
max-ports: 32
min-ports: 1
inherit:
config attributes:
  switchport mode trunk
  switchport trunk allowed vlan 20
  no shutdown
evaluated config attributes:
  no shutdown
assigned interfaces:
  Ethernet3/1
  Ethernet3/2
  Ethernet4/1
  Ethernet4/2
  Ethernet5/1
  Ethernet5/2
port-group: system-uplinks
system vlans: 20
capability l3control: no
capability iscsi-multipath: no
capability vxlan: no
capability l3-vservice: no
port-profile role: none
port-binding: static
My vethernet profiles:
port-profile mgmt
type: Vethernet
description:
status: enabled
max-ports: 32
min-ports: 1
inherit:
config attributes:
  switchport mode access
  switchport access vlan 20
  no shutdown
  no shutdown
  Vethernet1
  Vethernet3
  Vethernet4
  Vethernet6
  Vethernet7
  Vethernet13
  Vethernet18
port-group: mgmt
system vlans: 20
capability l3control: yes
port-profile ctrl-pkt
type: Vethernet
description:
status: enabled
max-ports: 32
min-ports: 1
inherit:
config attributes:
  no shutdown
  no shutdown
port-group: ctrl-pkt
system vlans: 20
cchildre
Beginner
Beginner
The capability L3 control setting is only for use on the port-profile that the VSM <--> VEM vmk.
You would need a second port-profile to put the VSMs on (all 3 interfaces on them can go in the same port-profile in L3 mode). Just be sure to set the vlan that it's set to as a system vlan.
adibenedetto18
Beginner
Beginner
Is your vCenter server using port-profile mgmt as the Network? I'm assuming your vCenter is a virtual server as well?
cchildre
Beginner
Beginner
Recognize Your Peers
