Nexus 1000V Layer3 capability issue
Hi all,
we have configured Nexus1000V with layer3 capability.
I have created a port-profile as follows:
port-profile type vethernet Vlan135
  switchport mode access
  switchport access vlan 135
  no shutdown
  capability l3control
  system vlan 135
  state enabled
  vmware port-group
vlan 135 is also configured as a system vlan, on my uplink port-profile and the svs-domain is configured as:
svs-domain
  domain id 6
  control vlan 1
  packet vlan 1
  svs mode L3 interface mgmt0
  switch-guid 6601da9c-6a20-43cd-91b6-8e0b16fc0d9d
  no enable l3sec
Every time there is a VSM switchover, I get the following message:
VEM_MGR-SLOT4-1-VEM_SYSLOG_ALERT: sfswitchdata : L3 Control and System VLAN configurations not applied
 on vethernet port. VMware Port[50331760] DVPortGroup[dvportgroup-90]. L3 Control can be applied only on VMKernel port.
What could be the problem?
Thanks in advance,
Katerina
Keny Perez
Level 11
Level 11
Is likely that you are using the port-profile "Vlan135" on a VM... the "capability l3control" is for the VMKernel on the host, only...hence the error.
-Kenny
Keny Perez
Level 11
Level 11
-Kenny
Hi Keny,
I created another port-profile for vlan135, without layer3 control capability. I then assigned all vms which should belong to vlan135, to the new port-profile and that resolved the issue.
Found these links really helpful:
https://communities.cisco.com/docs/DOC-28631
https://supportforums.cisco.com/document/12167596/nexus-1000v-vem-ports-blocking-state-after-reboot-esx-host
Thanks!
