Nexus 1000v with vSphere 6.5 (VCSA and ESXi-6.5)
Reuben Farrelly
Level 3
Level 3
I'd like to start off some discussion about the Nexus1000v with vSphere 6.5 which has just been released.
I have successfully run up a test ESXi and VCSA server and am looking at installing the N1kv in this environment.  Note:  I have had success and understanding of this from running this under VCSA-6.0 and ESXi-6.0 so I have used these products before - but not yet under 6.5.
As of now the N1kv is not officially supported/validated on this release but I'd like to get as far as I can with installing it anyway.  It looks like the problems may be mostly just about packaging and installation process rather than binary incompatibility.
So far the issues I have had are:
1. There is no vib to install on ESXi-6.5, and the ESXi-6.0 vib fails to install:
[root@vmware-2:~] esxcli software vib install -v /vmfs/volumes/55023178-7d2b0288-46fb-a0369f00f4aa/cross_cisco-vem-v320-5.2.1.3.2.5.0-6.0.1.vib
[DependencyError]
VIB Cisco_bootbank_cisco-vem-v320-esx_5.2.1.3.2.5.0-6.0.1 requires esx-base = 6.0.0, but the requirement cannot be satisfied within the ImageProfile.
Please refer to the log file for more details.
[root@vmware-2:~]
Is there a way to force this vem to load?  I believe - but haven't tested - that this vib should be compatible with ESXi-6.5
2. With the vSphere Desktop client no longer supported or functional with VCSA 6.5, how can we import the cisco_nexus_1000v_extension.xml file with the embedded certificate into VCSA?
3. Has there been any indication from Cisco as to the timeframe or supportability and/or updates of the N1kv to allow it to work seamlessly with vSphere 6.5?
33 Replies 33
I already have a working solution now so the problem is somewhat sorted :-)
VSUM doesn't (officially) support vCenter 6.5 though either right now, so I didn't test that option out at the time.
Peter Koltl
Level 7
Level 7
Awesome! Thanks
FWIW there is also a vSphere Custom Cisco Installation Image for vSphere 6.5 out now too.
https://my.vmware.com/group/vmware/details?downloadGroup=OEM-ESXI65-CISCO&productId=614
It doesn't seem to have any 1000V components.
Comparing the upgrade/profile.xml files, it looks like:
megaraid-sas changed from 6.603.55.00-2vmw to Avago 6.610.15.00-1OEM
scsi-fnic. changed from 1.5.0.45-3vmw to CSCO scsi-fnic 1.6.0.28-1OEM
Nexus 1000V 5.2(1)SV3(2.8) was just released and still indicates vmware 6.0 compatibility only.
