Nexus 5000 vPC throughput issues
vanderwaalr
Community Member
I have a client that is experiencing issues with the Nexus 5000 switches and vPC configuration.  They have a pair of Dell servers each with dual port Emulex CNA's installed.  When the server(s) are single homed to one Nexus 5000, using bandwidth throughput testing tools they see a sustained averaged throughput between the two servers of around the 9-9.5Gbps mark.  However, when they connect the server to both Nexus 5000's in a vPC configuration, the server throughput seems to drop down to around the 6-6.5Gbps mark.  The next odd thing is if one of the ports participating in the vPC is shutdown (or the interface is disconnected), the throughput almost immediately ramps up to the 9-9.5Gbps mark.  Then if the port/interface is re-established, the throughput drops back down to 6-6.5Gbps.
The Emulex software was used to create a static (no LACP) network team with Destination IP load balancing, although for the throughput tests only a connection between 2 servers was used so the traffic should be sent to/from the same interface for every packet.
The relavant parts of the Nexus 5000's configurations is below:
Nexus #1:
version 4.1(3)N1(1)
feature vpc
vpc domain 1
  peer-keepalive destination 192.168.77.6
vrf context management
  ip route 0.0.0.0/0 192.168.77.1
spanning-tree vlan 1-3967,4048-4093 priority 4096
interface port-channel27
  switchport mode trunk
  switchport access vlan 400
  switchport trunk native vlan 400
  vpc 27
  spanning-tree link-type point-to-point
  spanning-tree port type edge trunk
  spanning-tree guard loop
  speed 10000
interface port-channel28
  vpc 28
  speed 10000
interface port-channel100
  vpc peer-link
  spanning-tree port type network
  speed 10000
interface Ethernet1/9
  description To Nexus 5020 (vPC Peer Keepalive Link)
interface Ethernet1/27
  channel-group 27
interface Ethernet1/28
  channel-group 28
interface Ethernet1/33
  description To Nexus 5020 (vPC Peer Link)
  channel-group 100
interface Ethernet1/34
  channel-group 100
interface Ethernet1/35
  channel-group 100
interface Ethernet1/36
  channel-group 100
interface mgmt0
  ip address 192.168.77.5/25
cfs ipv4 distribute
cfs eth distribute
Nexus #2:
version 4.1(3)N1(1)
feature vpc
vpc domain 1
  peer-keepalive destination 192.168.77.5
spanning-tree vlan 1-3967,4048-4093 priority 8192
  vpc 27
  speed 10000
  vpc 28
  speed 10000
  vpc peer-link
  speed 10000
  channel-group 27
  channel-group 28
  channel-group 100
  channel-group 100
  channel-group 100
  channel-group 100
interface mgmt0
  ip address 192.168.77.6/25
cfs ipv4 distribute
cfs eth distribute
Server #1 is connected to Ports 27 on both Nexus 5000's, and Server #2 is connected to Port's 28 on both Nexus 5000's.  We have not, as yet, tested this all using LACP for negotiation of the virtual Port-Channels.
Can anyone suggest any ideas on what may be wrong or what we should look at?  Is the vPC configuration all correct?
Thanks in advance.
johgill
Level 5
Level 5
I know this is an old question, but I am curious if you saw the throughput issues perhaps tied to any one particular N5k in the vPC?
Did you perhaps have a SPAN configuration (switchport mode monitor) on one switch and not the other?
John Gill
