Nexus 7009 has issue with IPTV
Steev112
Hi All,
I have two nexus 7009 and connect one switch "IPVT switch" the model of this switch C3560G connected on it the IPTV server, and all other user switches the model for this either C3850 or C4500E connected to nexus by port-channel, the vlan for the IPTV server and IPTV device from the same range . the problem is I connect the IPVT device to any user switch the IPTV "channel is very slow" but if I connect the IPTV device on the IPTV switch is fast.
below the vlan configuration
interface Vlan40
  no shutdown
  ip address 10.10.40.253/24
  ip router eigrp 100
  hsrp version 2
  hsrp 40
    preempt
    priority 150
    ip 10.10.40.254
and the output on
Nexus
IGMP Snooping information for vlan 40
  IGMP snooping enabled
  Lookup mode: IP
  Optimised Multicast Flood (OMF) enabled
  IGMP querier present, address: 10.10.40.39, version: 2, i/f Eth3/6
  Switch-querier disabled
  IGMPv3 Explicit tracking enabled
  IGMPv2 Fast leave disabled
  IGMPv1/v2 Report suppression enabled
  IGMPv3 Report suppression disabled
  Link Local Groups suppression enabled
  Router port detection using PIM Hellos, IGMP Queries
  Number of router-ports: 2
  Number of groups: 3
  VLAN vPC function enabled
  Active ports:
    Po1 Po3     Po4     Po5
    Po6 Po11    Po12    Po13
    Po14        Po15    Po16    Po21
    Po22        Po23    Po24    Po25
    Po26        Po31    Po32    Po33
    Po34        Po35    Po36    Po1111
    Eth3/6      Eth3/26
4510
Vlan 40:
IGMP snooping                       : Enabled
IGMPv2 immediate leave              : Disabled
Explicit host tracking              : Enabled
Multicast router learning mode      : pim-dvmrp
CGMP interoperability mode          : IGMP_ONLY
Last member query interval          : 1000
can you please help me ?
attached the network diagram.
Steev112
Any one can help me for this?
What is your definition of "channel is very slow". Are you seeing tiling?
-Raj
