Nexus 7K port channels not pinging
AngelMorales
Friends,  I recently joined a new group, I am a novice on the 7k and was asked to bring up some new ports and assign them to port groups.  I did a stare and compare on the existing ports and followed suit.  The first interface on top and bottom works fine, the second interface the serves will not ping at all, when i disable one of the ports it works fine, can someone see what I’m doing wrong?
config on the two ports (1top1bottom) that are working fine
7kTop
interface Ethernet9/7
description OsdESX543_
switchport
switchport mode trunk
switchport trunk allowed vlan 2,184,306,309,900,902
spanning-tree port type edge trunk
mtu 9198
channel-group 907
no shutdown
interface port-channel907
description OsdESX543_trunk
switchport
mtu 9198
vpc 907
7k Bottom
switchport
mtu 9198
channel-group 907
no shutdown
switchport
mtu 9198
vpc 907
Config on the ports that will not ping if they are both on (when i take one down pings are successful)
7k Top
interface Ethernet9/5
description OsdESX541_
switchport
mtu 9198
channel-group 905
no shutdown
interface port-channel905
description OsdESX541_trunk
switchport
mtu 9198
vpc 905
7k Bottom
bottom# sh running-config interface ethernet 9/5
switchport
mtu 9198
channel-group 905
no shutdown
switchport
mtu 9198
vpc 905
Anyone have this issue before that can help?  Thanks!
balaji.bandi
What is the Server ? how is the Server configured - Active/Active or Active Standby ?
If you want to bundle the Link ? why they are configured 2 vPC 907 and 905 ?
BB
Sorry no the ports on Eth 9/7 top and bottom are configured on port channel 907 and are shown as an example because its working. The ports on Eth 9/5 top and bottom are configured the same way on port channel 905 but when both are up the server doesn't have any connectivity pings fail, if i take one down the other works fine.
the Servers are running esxi 6.0 U3 and from server end we are doing Active/Active NIC teaming. Load balancing - Route based on IP hash Network failure detection - link status only
thanks for any help
Is there any reason you can not bring all of them in one vPC ?
Look at the best practice of vPC with Nexus.
https://www.cisco.com/c/dam/en/us/td/docs/switches/datacenter/sw/design/vpc_design/vpc_best_practices_design_guide.pdf
BB
