Nexus 9k TCAM %ACLQOS-SLOT1-2-ACLQOS_OOTR: Tcam resource?
Ableton34
Hi all,
Need help with our new Nexus switches in our data centre, 9k.
We are getting the following message come up and ports being disabled due to the following:
exhausted: Ingress L2 QOS [ing-l2-qos]
On the Cisco site for these errors it states the action is:
No DDTS
I have no idea what No DDTS means? If this is the only resolution to this then that is a real problem as we have live services being affected by this TCAM resource being exhausted.
Anyone come across this or have a solution?
8 Replies 8
Andrea Testino
Are you seeing logs similar to the following in "show logging log":
2017 Mar 25 23:57:40 Nexus9K %ETHPORT-5-IF_DOWN_ERROR_DISABLED: Interface Ethernet1/10 is down (Error disabled. Reason:Sufficient free entries are not available in TCAM bank)
What you are seeing is not a defect (this is what NO DDTS also means, by the way). The switch is basically letting you know that you've exhausted the TCAM resources for a particular feature/configuration. In your case, the Ingress L2 QoS region.
You can view this via:
----`show system internal access-list resource utilization`----
slot  1
INSTANCE 0x0
            ACL Hardware Resource Utilization (Mod 1)
                                        Used    Free    Percent
                                                        Utilization
Ingress L2 QOS                          240     16      93.75
Ingress L2 QOS IPv4                    240             93.75
The TCAM for the Nexus 9000 must be carved correctly for the features/configuration that are needed. Once the TCAM is carved, a chassis reload will be required to program the switch for the new carving and regions.
Here's the Nexus 9000 TCAM Carving Guide
Hope that helps.
- Andrea
- Andrea, CCIE #56739 R&S
Thanks.
We are applying QoS on both uplinks and access ports.
Do you think this is why we are running out of memory?
Hi there,
Well, it is okay to apply QoS to Layer 2 interfaces; however, the TCAM would've needed to be carved correctly for Ingress Layer 2 QoS so the switch can support the configuration for said amount of interfaces.
Hope that helps.
- Andrea
Thanks.
We have attempted to prevent the exhausted tcam by taking memory from other services on the switches but concerned we may cause problems with other functions.
Could the issue be with the QoS policy itself do you think?
If we remove the QoS completely the issue subsides.
Do you have a guide as to the best way to carve the tcam for an intensive QoS policy at layer 2?
Can you share the output to the following - I'll see what you have enabled and what is currently carved and make a suggestion based on that:
show module
show run | i feature
sh hardware access-list tcam region
show hardware access-list resource utilization
- Andrea
HQDC-ACC-SW-02A# show module
Mod Ports             Module-Type                       Model          Status
1    54   48x10GT + 6x40G/100G Ethernet Module  N9K-C93108TC-EX       active *
Mod  Sw                Hw     Slot
1    7.0(3)I4(2)       1.0    NA
Mod  MAC-Address(es)                         Serial-Num
1    00-a6-ca-09-77-90 to 00-a6-ca-09-77-df  FDO203308SH
Mod  Online Diag Status
1    Pass
* this terminal session
HQDC-ACC-SW-02A# show run | i feature
feature scp-server
feature tacacs+
feature eigrp
feature udld
feature interface-vlan
feature lacp
feature vpc
feature lldp
feature vtp
HQDC-ACC-SW-02A# sh hardware access-list tcam region
                                    NAT ACL[nat] size =    0
                        Ingress PACL [ing-ifacl] size =    0
                                     VACL [vacl] size =    0
                         Ingress RACL [ing-racl] size =  512
                       Ingress RBACL [ing-rbacl] size =    0
                     Ingress L2 QOS [ing-l2-qos] size = 1536
           Ingress L3/VLAN QOS [ing-l3-vlan-qos] size =  512
                           Ingress SUP [ing-sup] size =  512
     Ingress L2 SPAN filter [ing-l2-span-filter] size =  256
     Ingress L3 SPAN filter [ing-l3-span-filter] size =  256
                       Ingress FSTAT [ing-fstat] size =    0
                                     span [span] size =  512
                          Egress RACL [egr-racl] size = 1792
                            Egress SUP [egr-sup] size =  256
                 Ingress Redirect [ing-redirect] size =    0
HQDC-ACC-SW-02A# show hardware access-list resource utilization
slot  1
INSTANCE 0x0
                                        Used    Free    Percent
                                                        Utilization
Ingress L2 QOS                          1408    128     91.67
 Ingress L2 QOS IPv4                    1360            88.54
 Ingress L2 QOS IPv6                    32              2.08
 Ingress L2 QOS MAC                     16              1.04
 Ingress L2 QOS ALL                     0               0.00
 Ingress L2 QOS OTHER                   0               0.00
Ingress L2 SPAN ACL                     0       256     0.00
 Ingress L2 SPAN ACL IPv4               0               0.00
 Ingress L2 SPAN ACL IPv6               0               0.00
 Ingress L2 SPAN ACL MAC                0               0.00
 Ingress L2 SPAN ACL ALL                0               0.00
 Ingress L2 SPAN ACL OTHER              0               0.00
Ingress RACL                            0       512     0.00
 Ingress RACL IPv4                      0               0.00
 Ingress RACL IPv6                      0               0.00
 Ingress RACL MAC                       0               0.00
 Ingress RACL ALL                       2               0.39
 Ingress RACL OTHER                     0               0.00
Ingress L3/VLAN QOS                     4       508     0.78
 Ingress L3/VLAN QOS IPv4               0               0.00
 Ingress L3/VLAN QOS IPv6               0               0.00
 Ingress L3/VLAN QOS MAC                0               0.00
 Ingress L3/VLAN QOS ALL                4               0.78
 Ingress L3/VLAN QOS OTHER              0               0.00
Ingress L3/VLAN SPAN ACL                0       256     0.00
 Ingress L3/VLAN SPAN ACL IPv4          0               0.00
 Ingress L3/VLAN SPAN ACL IPv6          0               0.00
 Ingress L3/VLAN SPAN ACL MAC           0               0.00
 Ingress L3/VLAN SPAN ACL ALL           0               0.00
 Ingress L3/VLAN SPAN ACL OTHER         0               0.00
Ingress SUP                             396     76      83.90
 Ingress SUP IPv4                       129             27.33
 Ingress SUP IPv6                       176             37.29
 Ingress SUP MAC                        35              7.42
 Ingress SUP ALL                        10              2.12
 Ingress SUP OTHER                      46              9.75
SPAN                                    0       512     0.00
 SPAN IPv4                              0               0.00
 SPAN IPv6                              0               0.00
 SPAN MAC                               0               0.00
 SPAN ALL                               0               0.00
 SPAN OTHER                             0               0.00
Egress RACL                             0       1792    0.00
 Egress RACL IPv4                       0               0.00
 Egress RACL IPv6                       0               0.00
 Egress RACL MAC                        0               0.00
 Egress RACL ALL                        2               0.11
 Egress RACL OTHER                      0               0.00
Egress SUP                              128     128     50.00
 Egress SUP IPv4                        0               0.00
 Egress SUP IPv6                        0               0.00
 Egress SUP MAC                         0               0.00
 Egress SUP ALL                         0               0.00
 Egress SUP OTHER                       128             50.00
Feature BFD                             2       14      12.50
 Feature BFD IPv4                       0               0.00
 Feature BFD IPv6                       0               0.00
 Feature BFD MAC                        0               0.00
 Feature BFD ALL                        2               12.50
 Feature BFD OTHER                      0               0.00
Feature DHCP SNOOP                      0       16      0.00
 Feature DHCP SNOOP IPv4                0               0.00
 Feature DHCP SNOOP IPv6                0               0.00
 Feature DHCP SNOOP MAC                 0               0.00
 Feature DHCP SNOOP ALL                 0               0.00
 Feature DHCP SNOOP OTHER               0               0.00
Feature ARP SNOOP                       0       2       0.00
 Feature ARP SNOOP IPv4                 0               0.00
 Feature ARP SNOOP IPv6                 0               0.00
 Feature ARP SNOOP MAC                  0               0.00
 Feature ARP SNOOP ALL                  0               0.00
 Feature ARP SNOOP OTHER                0               0.00
Feature VxLAN OAM                       0       2       0.00
 Feature VxLAN OAM IPv4                 0               0.00
 Feature VxLAN OAM IPv6                 0               0.00
 Feature VxLAN OAM MAC                  0               0.00
 Feature VxLAN OAM ALL                  0               0.00
 Feature VxLAN OAM OTHER                0               0.00
Feature DHCPv6 RELAY                    0       4       0.00
 Feature DHCPv6 RELAY IPv4              0               0.00
 Feature DHCPv6 RELAY IPv6              0               0.00
 Feature DHCPv6 RELAY MAC               0               0.00
 Feature DHCPv6 RELAY ALL               0               0.00
 Feature DHCPv6 RELAY OTHER             0               0.00
LOU                                     8       8       50.00
Both LOU Operands                       8
Single LOU Operands                     0
LOU L4 src port:                        3
LOU L4 dst port:                        5
LOU L3 packet len:                      0
LOU IP tos:                             0
LOU IP dscp:                            0
LOU ip precedence:                      0
LOU ip TTL:                             0
TCP Flags                               0       16      0.00
Protocol CAM                            2       244     0.81
Mac Etype/Proto CAM                     0       14      0.00
Non L4op labels, Tcam 0                 16      14      53.33
Non L4op labels, Tcam 1                 0       62      0.00
Non L4op labels, Tcam 2                 0       4095    0.00
Non L4op labels, Tcam 3                 1       1022    0.09
Non L4op labels, Tcam 4                 0       0       0.00
L4 op labels, Tcam 5                    0       1023    0.00
L4 op labels, Tcam 6                    0       1023    0.00
L4 op labels, Tcam 7                    0       1024    0.00
L4 op labels, Tcam 8                    0       254     0.00
L4 op labels, Tcam 9                    0       1023    0.00
L4 op labels, Tcam 10                   0       1023    0.00
L4 op labels, Tcam 11                   0       1023    0.00
L4 op labels, Tcam 12                   0       1023    0.00
L4 op labels, Tcam 13                   0       1023    0.00
L4 op labels, Tcam 14                   0       1023    0.00
L4 op labels, Tcam 15                   0       1023    0.00
L4 op labels, Tcam 16                   0       1023    0.00
Ingress Dest info table                 0       512     0.00
Egress Dest info table                  0       512     0.00
Note: Ingress SUP region includes the Redirect region
INSTANCE 0x1
                                        Used    Free    Percent
                                                        Utilization
Ingress L2 QOS                          1144    392     74.48
 Ingress L2 QOS IPv4                    1105            71.94
 Ingress L2 QOS IPv6                    26              1.69
 Ingress L2 QOS MAC                     13              0.85
SPAN                                    0       512     0.00
 SPAN IPv4                              0               0.00
 SPAN IPv6                              0               0.00
 SPAN MAC                               0               0.00
 SPAN ALL                               0               0.00
 SPAN OTHER                             0               0.00
LOU                                     8       8       50.00
Both LOU Operands                       8
LOU L4 src port:                        3
LOU L4 dst port:                        5
LOU IP tos:                             0
LOU IP dscp:                            0
LOU ip TTL:                             0
TCP Flags                               0       16      0.00
Non L4op labels, Tcam 0                 13      17      43.33
Non L4op labels, Tcam 5                 0       1023    0.00
Non L4op labels, Tcam 6                 0       1023    0.00
Non L4op labels, Tcam 7                 0       1024    0.00
Non L4op labels, Tcam 8                 0       254     0.00
Non L4op labels, Tcam 9                 0       1023    0.00
Non L4op labels, Tcam 10                0       1023    0.00
Non L4op labels, Tcam 11                0       1023    0.00
Non L4op labels, Tcam 12                0       1023    0.00
Non L4op labels, Tcam 13                0       1023    0.00
Non L4op labels, Tcam 14                0       1023    0.00
Non L4op labels, Tcam 15                0       1023    0.00
Non L4op labels, Tcam 16                0       1023    0.00
L4 op labels, Tcam 0                    13      17      43.33
L4 op labels, Tcam 1                    0       62      0.00
L4 op labels, Tcam 2                    0       4095    0.00
L4 op labels, Tcam 3                    1       1022    0.09
L4 op labels, Tcam 4                    0       0       0.00
Ideally we would like a recommendation on services we can afford to lose without causing us future problems or losing span (which we need)
thanks again
Hi there,
Below is a suggestion based on the utilization I see for your device currently:
Ingress RACL is not being utilized in this particular box:
                         Ingress RACL [ing-racl] size =  512 <<< Ingress RACL
                                        Used    Free    Percent
                                                        Utilization
Ingress L2 QOS                          1408    128     91.67 <<< Very close to 100%
<snip>
Ingress RACL                            0       512     0.00 <<< Ingress RACL not being used at all
<snip>
You could then lower the Ingress RACL TCAM size significantly to allow Ingress L2 QoS to take more of it.
Example:
Nexus9K(config)# hardware access-list tcam region ing-racl 0
Warning: Please save config and reload the system for the configuration to take effect
Nexus9K(config)# hardware access-list tcam region ing-l2-qos 2048
Nexus9K# copy r s
[########################################] 100%
Copy complete, now saving to disk (please wait)...
Copy complete.
Nexus9K# reload
This command will reboot the system. (y/n)?  [n] y
End Result:
Nexus9K# show hardware access-list tcam region
                         Ingress RACL [ing-racl] size =    0  << Ing RACL is now 0
                     Ingress L2 QOS [ing-l2-qos] size = 2048  <<< Larger TCAM size
                           Ingress NBM [ing-nbm] size =    0
Essentially, I've increased the Ingress L2 QoS TCAM size by 512 which should allow for more QoS configuration on L2 ports. Do keep in mind of course you can still hit the limit in the future as more L2 ports are configured with input service policies; however, this re-carve should allow you to "squeeze" a few more.
Hope that helps.
- Andrea
That's great thanks for your help.
Someone else has suggested we only configure the marking on the uplinks to the distribution switches.
Would you agree that this is ok, will it still mark correctly?
