Nexus Fabric Extenders, config mismatch between downstream 5Ks?
johnnylingo
Level 5
Level 5
I'm evaluating the Nexus 2248TP Fabric Extenders as replacement for our older 3750E and 2960 switches.  I have the 2248 uplinked to a pair of 5548s, both switches report the Fex "online" and successfully bundled the ports in to a vPC.  Everything seems to work fine.
Where I'm confused on is configuration - since this is not shared between the 5548s, what is the source of truth for a port configuration on the Fex with there is disagreement?   For example, given this configuration...
N5548-1# show run int e116/1/1
version 7.0(8)N1(1)
interface Ethernet116/1/1
  switchport access vlan 111
  spanning-tree port type edge
N5548-2# show run int e116/1/1
version 7.0(8)N1(1)
  switchport access vlan 222
Will this port be in vlan 111 or vlan 222?
Reza Sharifi
When you dual home your FEXes to  2 5ks, in order for the ports to work correctly they must have identical configs on both switches. So, the config you posted should not work.
version 7.0(8)N1(1)
version 7.0(8)N1(1)
Well yes, but is there a way to guard against this, or auto-sync the configuration between the 5ks?
Yes, you can use config sync, so you don't have to do it manually.
here is a link to it
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus5000/sw/operations/n5k_config_sync_ops.html
