Nexus SNMP interface error
zheepern0826
Level 3
Level 3
Hi experts,
Recently I found there is high transmit error from few nexus 5548 interface from my monitoring system.  You may see from the attached image.
I tried to use snmpwalk to walk and below is the result.
IF-MIB::ifDescr.436211712 = STRING: Ethernet1/2
IF-MIB::ifOutErrors.436211712 = Counter32: 6308517
Seems there is error occur so I log in switches and check the interface:
Ethernet1/2 is up
  Hardware: 1000/10000 Ethernet, address: xxxx.xxxx.xxxx (bia xxxx.xxxx.xxxx)
  Description: fex link to FEX-102
  MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec
  Encapsulation ARPA
  Port mode is fex-fabric
  full-duplex, 10 Gb/s, media type is 10G
  Beacon is turned off
  Input flow-control is off, output flow-control is off
  Rate mode is dedicated
  Switchport monitor is off
  EtherType is 0x8100
  Last link flapped 410week(s) 4day(s)
  Last clearing of "show interface" counters 189w3d
  30 seconds input rate 1700136 bits/sec, 525 packets/sec
  30 seconds output rate 2034488 bits/sec, 725 packets/sec
  Load-Interval #2: 5 minute (300 seconds)
    input rate 3.10 Mbps, 532 pps; output rate 3.61 Mbps, 700 pps
  RX
    849545099092 unicast packets  108778327 multicast packets  222943515 broadcast packets
    849876820934 input packets  899832297687670 bytes
    508037712184 jumbo packets  0 storm suppression bytes
    0 runts  0 giants  0 CRC  0 no buffer
    0 input error  0 short frame  0 overrun   0 underrun  0 ignored
    0 watchdog  0 bad etype drop  0 bad proto drop  0 if down drop
    0 input with dribble  0 input discard
    0 Rx pause
  TX
    311597349364 unicast packets  3415269283 multicast packets  1722601701 broadcast packets
    316735220348 output packets  131141128972374 bytes
    46161511546 jumbo packets
    0 output errors  0 collision  0 deferred  0 late collision
    0 lost carrier  0 no carrier  0 babble 0 output discard
    0 Tx pause
  0 interface resets
Based on the result in the switches, I can't see any error occur.
Can anyone give some advise on this ?
Thank you very much in advance.
Kirk J
Greetings.
That sounds like a bug.
I found a similar one for the UCSM, but haven't found one describing your specific counter issue for the N5k.
What code level are you running?
You may want to open a TAC ticket, and see if they can ID the bug, and fixed in version (if one exists).
Kirk...
I am logging at notification level. Maybe will open a TAC case and check with support.
Thanks for your advise. 🙂
