Nexus switch compatibility.
hpacheco3621
Community Member
I have a SG500-52P Switch with 1000BASE-BX-20U SFP (SKU: MGBSX1)  and we purchased a new Nexus 3524 Switch that has 10G SFP+ (SKU: SFP-10G-SR).  Can I interconnect these two switches? Any compatibility issue?  We will be uninstalling the SG500 after we complete the migration.
7 Replies 7
ahmedshoaib
Level 9
Level 9
Hi;
To connect  these to switches you need either GLC-T(1G UTP) or GLC-SX-MM(1G Fiber) on Nexus 3524 switch.
We
Thanks & Best regards;
Which cable (model number) needs to be used for the connectivity?
Hi;
If you are using GLC-T then you can use CAT-5e or CAT-6 Cable.
And if you are using GLC-SX-MMD then you can use LC-LC fiber patch cord.
So do I need the GLC-SX-MMD connected on both the SG500 and the Nexus 3524? Two SFP's?
Thanks in advance.
Yes.
Thank you.
hpacheco3621
Community Member
