Nexus Switching Mode
nasirbh78
Is there way to check nexus switching mode before restarting switch. I have to find out whether it is under cut through or store and forward mode . Is there any command to check ?
Seb Rupik
Hi there,
Have you tried the command:
sh switching-mode
cheers,
Seb.
Andrea Testino
You could check two ways, I suppose. See below:
switch# show switching-mode
Configured switching mode: Cut through
Module Number                   Operational Mode
     1                          Cut-Through
     2                          Cut-Through
     3                          Cut-Through
     4                          Cut-Through
     21                         Cut-Through
     22                         Cut-Through
     23                         Cut-Through
     24                         Cut-Through
     25                         Cut-Through
     26                         Cut-Through
Or alternatively:
switch# show run all | i i store-forward
no switching-mode store-forward
Hope that helps.
- Andrea
- Andrea, CCIE #56739 R&S
this command only works on cisco 9k switches but not on 7k series, Is that any other commands where we can find it?
sh switching-mode
