Nexus5010 Chassis Interface Inventory and typ of module
vineethmohan
Hi Support,
All  other cisco Switch models  sh inventory commands will show the sl number  and type  of the module inserted on the switch ports   any such commands available on  Nexus5010 switch to know the  sl number and media type  .
OS Version :version 4.0(1a)N1(1)
Vineeth Mohan
abbharga
Level 4
Level 4
Vineeth,
show module should help you.
./Abhinav
Hi Abhinav ,
I have tried that frist but it  was not helpful for me .  Sh module is only giving the below out put .
Kindly share  if you have any  feedback  .
Rgeards
Vineeth
Hi Abhinav ,
Thanks for your help  . How  ever  I have got a command which helped me to find the sl number of the modules
"show interface ethernet 1/1 transceiver details"
Vineeth
Oleksandr Nesterov
You can use command "show interface ethernet x/y", it will give you following output:
Nexus# sh int e 1/2 transceiver
Ethernet1/2
    transceiver is present
    type is 10Gbase-SR
    name is CISCO-FINISAR
    part number is FTLX8571D3BCL-CS
    revision is E
    serial number is FNSXXXXXXXX
    nominal bitrate is 10300 MBit/sec
    Link length supported for 50/125um fiber is 80 m
    Link length supported for 50/125um fiber is 300 m
    Link length supported for 62.5/125um fiber is 20 m
    cisco id is --
    cisco extended id number is 4
