Problems with MS NLB over vPC using N5K and 6509E
Justin DeVaughn
I've attached a visio diagram of the configuration for reference.
I'm having two problems:
1.  I cannot ping the VIP 10.10.1.1 on the MS NLB servers from other subnets on their ODD numbered IPs.  For instance 192.168.1.1 cannot ping the VIP while 192.168.1.2 can ping the VIP.
2.  N5K-1 cannot ping the VIP while N5K-2 can ping the VIP.
I  have the requisite ARP 10.10.1.1 (insert multicast mac here) ARPA command on the 6509E
I  have the Mac address-table static (insert multicast mac here) vlan 10 interface (list interfaces over to N5K e.g...TenGigabitEthernet1/1)
Every connection is vPC'd in the same configuration as below: 6509E --> N5K's --> ESXi hosts
I'm not sure where to begin troubleshooting!  These are CAS servers so they are affecting e-mail.  any help is definitely appreciated!
Currently the load balancing is being done with the following command:
port-channel load-balance ethernet source-dest-mac
Below is the configuration for the N5K's in sync mode:
interface port-channel1
  description ESX1
  switchport mode trunk
  vpc 1
  switchport trunk native vlan 5
  switchport trunk allowed vlan 1,5-6,10-12,57-58
  spanning-tree port type edge
interface port-channel2
  description ESX2
  vpc 2
interface port-channel3
  description ESX3
  vpc 3
interface Ethernet1/1
  description ESX1
  channel-group 1
interface Ethernet1/2
  description ESX2
  channel-group 2
interface Ethernet1/3
  description ESX3
  channel-group 3
5 Replies 5
Reza Sharifi
Is vPC configured correctly between the 5ks?
What is is the output of "sh vpc"
What device is the root bridge?
Reza,
Attached are the commands you were looking for.
Interestingly the N5K1 STP roots across the vPC peer link with N5K2
N5K2 STP roots across the PortChannel up to the 6500...
NEXUS5K#1
VLAN0001
  Root ID    Priority    200
             Address     0015.c7f5.bc01
             Cost        2
             Port        4348 (port-channel253)
             Hello Time  2  sec  Max Age 20 sec  Forward Delay 15 sec
VLAN0004
  Root ID    Priority    8192
             Address     0015.c7f5.bc04
             Cost        2
VLAN0005
             Address     0015.c7f5.bc05
             Cost        2
VLAN0006
             Address     0015.c7f5.bc06
             Cost        2
VLAN0007
  Root ID    Priority    32768
             Address     0015.c7f5.bc07
             Cost        2
VLAN0008
             Address     0015.c7f5.bc08
             Cost        2
VLAN0010
             Address     0015.c7f5.bc0a
             Cost        2
# sh vpc
Legend:
                (*) - local vPC is down, forwarding via vPC peer-link
vPC domain id                   : 253
Peer status                     : peer adjacency formed ok
vPC keep-alive status           : peer is alive
Configuration consistency status: success
Per-vlan consistency status     : success
Type-2 consistency status       : success
vPC role                        : secondary
Number of vPCs configured       : 102
Peer Gateway                    : Disabled
Dual-active excluded VLANs      : -
Graceful Consistency Check      : Enabled
vPC Peer-link status
id   Port   Status Active vlans
1    Po253  up     1,4-8,10-12,15,20,30,35,40,44,50-58,60,65,70,72,75
                   ,80,85,90,95,100,105,110,115,120,125,130,135,140,1
                   45,150,155,160,165,170,175,180,185,190,195,200,205
                   ,210,215,220,225,230,235,240,245,250,500
vPC status
id     Port        Status Consistency Reason                     Active vlans
100    Po100       up     success     success                    -
101    Po101       up     success     success                    -
240    Po240       up     success     success                    1,5-6,10-12
        ,57-58
241    Po241       up     success     success                    1,5-6,10-12
        ,57-58
242    Po242       up     success     success                    1,5-6,10-12
        ,57-58
250    Po250       up     success     success                    1,4-8,10-12
        ,15,20,30,3
        5,40,44,50-
        58,60,65,70
        ,72,75,....
NEXUS5K #2
VLAN0001
             Cost        1
             Port        4345 (port-channel250)
VLAN0004
             Cost        1
VLAN0005
             Cost        1
VLAN0006
             Cost        1
VLAN0007
             Cost        1
VLAN0008
             Cost        1
VLAN0010
             Cost        1
# sh vpc
Legend:
vPC domain id                   : 253
vPC role                        : primary
vPC status
        ,57-58
        ,57-58
        ,57-58
        ,15,20,30,3
        5,40,44,50-
        58,60,65,70
        ,72,75,....
zahir_ahmed
Hi Justin,
Did you ever get this issue sorted out?
I am about to configure the same and just wanted to check the correct way of doing this with N5K and Cisco 6509E as the L3 device doing all the routing..
Any advice will be much appreciated..
Zee
Unfortunately, I did not.  The ultimate problem with how this affected the customer was that half of their VDI environment sourced off servers connected to N5K1 and the other half through N5K2.  The VDI desktops that were sourced through N5K1 servers received odd number IP addresses and could not reach the CAS e-mail Virtual IP Address.  I ended up pointing DNS to one of the real IP's instead of the VIP for the VDI environment - since it was easy enough to scale and fixed the issue.
TAC and I took packet captures and were able to detect the traffic switching properly out the N5K2 port with the VMWare -> CAS servers on it after hairpinning through the 6509E etherchannel.  At that point it was a VMware/Server issue which was resolved by recommending a hardware network load balancer - I don't believe the customer ever implemented the hardware network load balancer (because DNS band-aided it) but it was the course of action their Microsoft Partner recommended as well.
What are the NIC teaming settings on the servers? How is teaming and NLB combined?
