Problems with uninstalling VEM VIB
mtrcek
We are trying to uninstall vib files from ESXi5.1, but when we did, it says that resource is busy. We've rebooted the system, but still the same problem.
We tried to find which process locks the file with " lsof -D ", but there is no process which locks it. What to do?
~ # esxcli software vib remove -n cisco-vem-v150-esx
[InstallationError]
Error in running rm /tardisks/cisco_ve.v00:
Return code: 1
Output: rm: can't remove '/tardisks/cisco_ve.v00': Device or resource busy
It is not safe to continue. Please reboot the host immediately to discard the unfinished update.
Please refer to the log file for more details.
mtrcek
Ok, "vem stop" helped...
lwatta
Interesting. I've not run into that before. Are you sure all the nics and vms had been removed from the N1KV before you ran the esxcli command?
louis
mtrcek
Yes. I was surprised, too.
Sent from Cisco Technical Support Android App
