qllc to sdlc conversion
florind
I'm trying to do QLLC TO SDLC conversion for this setup:
Remote units using SDLC PADs to access a public x.25 network come to a x25 access in a Cisco router. From the router I have an SDLC connection to the Host.
It is working fine for one device, but I cannot make it working for 2 remote units at the same time. I cannot define more than 1 partner under the "qllc dlsw vmacaddr 0302.0302.10c1 3 partner 0303.0303.10c1". I know that I can use the subaddress field but this will not help as all the remote devices are calling the same addresses and there is no subaddress field.
Please advice,
Florin
version 11.2
service timestamps debug datetime
service timestamps log datetime
service password-encryption
no service udp-small-servers
no service tcp-small-servers
hostname QLLC_TEST
enable secret 5 <removed>
enable password 7 <removed>
no ip routing
source-bridge ring-group 999
dlsw local-peer
interface Serial0
no ip address
encapsulation x25
no ip route-cache
no ip mroute-cache
x25 address 99999999
x25 htc 5
x25 win 3
x25 wout 3
x25 ips 256
x25 ops 256
x25 map qllc 0302.0302.10c2 22222222 accept-reverse
x25 map qllc 0302.0302.10c3 33333333 accept-reverse
x25 map qllc 0302.0302.10c1 11111111 accept-reverse
interface Serial1
no ip address
encapsulation sdlc
no ip route-cache
no ip mroute-cache
no keepalive
clockrate 2400
sdlc role secondary
sdlc vmac 0303.0303.1000
sdlc address C1
sdlc partner 0302.0302.10c1 C1
sdlc address C2
sdlc partner 0302.0302.10c2 C2
sdlc address C3
sdlc partner 0302.0302.10c3 C3
sdlc dlsw C1 C2 C3
interface TokenRing0
no ip address
no ip route-cache
no ip mroute-cache
shutdown
ring-speed 16
no ip classless
logging buffered 80000 debugging
bridge 1 protocol dec
line con 0
login
line aux 0
line vty 0 4
login
end
IOS (tm) 2500 Software (C2500-IS-L), Version 11.2(15a)P, P RELEASE SOFTWARE (fc1
Copyright (c) 1986-1998 by cisco Systems, Inc.
Compiled Tue 25-Aug-98 00:28 by kpma
Image text-base: 0x03030170, data-base: 0x00001000
ROM: System Bootstrap, Version 11.0(10c)XB1, PLATFORM SPECIFIC RELEASE SOFTWARE
(fc1)
BOOTFLASH: 3000 Bootstrap Software (IGS-BOOT-R), Version 11.0(10c)XB1, PLATFORM
SPECIFIC RELEASE SOFTWARE (fc1)
QLLC_TEST uptime is 5 days, 8 hours, 1 minute
System restarted by power-on at 09:01:00 UTC Thu Jun 27 2002
System image file is "flash:c2500-is-l.112-15a.p", booted via flash
cisco 2525 (68030) processor (revision J) with 6144K/2048K bytes of memory.
Processor board ID 08868334, with hardware revision 00000000
Bridging software.
X.25 software, Version 2.0, NET2, BFE and GOSIP compliant.
1 Token Ring/IEEE 802.5 interface(s)
2 Serial network interface(s)
5-in-1 module for Serial Interface 0
5-in-1 module for Serial Interface 1
32K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read ONLY)
rsissons
Level 5
Level 5
I do not see any way you can do this without using subaddresses which will enable you to map to multiple partner mac addresses.
