Span Monitor clients over layer3 link
chpmotry
Hi guys.
I have two units with separate networks that are connected to the core switch through static route(I have attached the network schematic image below ). I want to monitor the traffic of my clients who are in different units in a span server behind the core switch. My switches model are 2960x and core switch model is c4507 .
What should I do so that the traffic of the clients goes to the span server?
Kirk J
ESXi dVS can support ERspan, which you could then send to the C4507, which also supports ERspan.
You are pretty limited without some 2960<>4507 L2 links where you could use rspan.
With L3 boundaries, you are likely going to need ERspan capable devices (this excludes 2960s).
Kirk...
