stun problem
c.chunxia
I have a connection like this:
pu 2.0---r1--r---r----r------r2----390
r1#sh stun
This peer: 10.1.1.2
*Serial6/1 (group 1 [sdlc])
state rx_pkts tx_pkts drops poll
C8 TCP 10.1.2.1 close * 6752 4023 0
SDLC Local Acknowledgement:
slack_state conn disc iframe_s iframe_r
C8 TCP 10.1.2.1 disconnect 11 10 668 754
r1#ping 10.1.2.1
Success rate is 100 percent (5/5), round-trip min/avg/max = 128/130/132 ms
I don't know why my pu is down even if ip connection is correct.(There is none operation on 390 and pu2.0)
thank you!
c.chunxia
r1 configuration is:
stun peer-name 10.1.1.2
stun protocol-group 1 sdlc
stun remote-peer-keepalive
interface Serial6/1
no ip address
encapsulation stun
nrzi-encoding
clockrate 64000
stun group 1
stun sdlc-role primary
sdlc address C8
stun route address C8 tcp 10.1.2.1 local-ack
You need to have traffic on the connection before the STUN peer will come up so the mainframe side will have to initiate the connection. A 'debug stun pac' at the mainframe end will tell you if the mainframe is currently trying to activate the PU.
