Sup Module replace at N7k at Single Sup design
thiru.vel10
N7K A and N7K B has single Sup module, N7KB VPC role is secondary .N7KA vac role is primary ( as per the Role Priority and Preempt not configured). Need to replace the Sup module
at N7K A without any down time.   Please suggest the Process.
Note : New Sup has target NSIOS and Servers are connected as Dual Homing scenario.  Attached diagram for your reference .
According to the following Cisco documentation you can replace a standby supervisor module and copy the nx-os from the active supervisor module to the standby supervisor module.
http://www.cisco.com/en/US/docs/switches/datacenter/sw/5_x/nx-os/high_availability/configuration/guide/ha_system.html#wp1081756
