Temperature thresold - Nexus 7010
pradeepser
In Nexus 7010
Hi Team,
In N7010 when i checked the environment status i can see minimum thresold is set to 105 celsius but it documents its mentioned the operation temperature is 0 to 40 celsius. In sh environ temp output i can see the below sensor is 65 Celsius
Temperature:
Module   Sensor        MajorThresh   MinorThres   CurTemp     Status
                       (Celsius)     (Celsius)    (Celsius)
2        QEng1Sn1(s6)    115             105         65         Ok
Is the thresold values are hardcoded or can be changed in Nexus 7010?
Rgds,
Prdp
phiharri
Greetings,
The thresholds displayed in 'show environment temperature' are for internal components and are not user-configurable. Nexus 7010 and 7018 chassis are suited to operate with an external environment temperature between 0 and 40ºC.
Cheers,
/Phil
