UCS 6120xp fabric interconnect power supply
HrvojeStargl
Hi guys,
I have Cisco UCS 6120xp fabric interconnect, with two N10-PAC1-550W power supplies.One power supply is dead.
Power supply N10-PAC1-550W is EoS, and the replacement is UCS-PSU-6296UP-AC.
Will fabric interconnect work with mix of those two power supplies? Anyone have situation like that?
Thanks in advance.
Keny Perez
Level 8
Level 8
According to: http://www.cisco.com/c/en/us/products/collateral/servers-unified-computing/ucs-6100-series-fabric-interconnects/eol_c51-709473.html ; : N10-PAC1-550W is replaced with UCS-PSU-6248UP-AC  and not UCS-PSU-6296UP-AC.
That is the official replacement Part ID, it should not have any problems
-Kenny
Keny Perez
Level 8
Level 8
-Kenny
Thank you Keny,
My mistake, I copied the wrong part number from the table.
no problem.. if it helped, rate it... if it answered your question, marked it as such.
-Kenny
