UCS B and Spine Leaf Question
jn242
I am a bit confused and need some clarity.
In a leaf spine topo you want each leaf connnecting to each spine and not to each other.
If i have 1 rack with a pair of 93xx series switches (2 for redundancy), or any other switches for that matter, is that one leaf or two? I assume it is 2 and you want each then to be wired back to the spine. NO connectivity between the 2 switches.
IN reviewing this graphic they have 4 spines adn only 4 connections to the spines despite having 2 93xx switches per rack.
Does that mean you are supposed to somehow make the 2 switches look like 1 switch to the upstream spines or did they omit the addtional connections from the second 93xx for simplicity sake and there are really 4 per 93xx?
https://image.slidesharecdn.com/net8364rfullermancusofinal-161018074554/95/vmworld-2016-how-to-deploy-vmware-nsx-with-cisco-infrastructure-13-638.jpg?cb=1476798226
Rick1776
Level 5
Level 5
You care correct, each leaf is connected to each spine via a single connection. Each leaf can be connected to one another via a vPC (virtual port-channel). You are correct there is no physical connection between the Leafs but you can still configure a vPC.
Check out this guide...
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/aci/apic/sw/2-x/GSG/b_APIC_Getting_Started_Guide_Rel_2_x/b_APIC_Getting_Started_Guide_Rel_2_x_chapter_0100.html
