veth drops on nexus1000v toward vmk
fedcre
Hi all,
during a troubleshooting analisys I've noted a lot of drops on some of Nexus1000v interfaces.
The 1000v is in an architecture with N7k-UCS FI 6296-UCS blade M series- Vmware Esxi5.1
1000v version is 4.2(1)SV1(5.2)
In particular the drops occurred on veth interfaces toward vmk for Vmotion and Vxlan (two different vmkx- vmk2/vmk3) , and on uplink portchannel dedicated to vxlan and vmotion.
Vxlan implementation is a L2 one.
On portchannel we use mac address pinning toward UCS End Host Mode, so the drops are quite normal ( broadcast/multicast on non designated port), but i'm worried about the drops on vmk.
I've cleared the counters on one of the veth interface, and the drops are still 0, no increment.
Someone can help me to investigate about the problem ?
Maybe some Mtu issue on Dvswitch, or on ESxi  ?
Or some performance issue ? I think these drops occur  during a peak of traffic toward a customer VM ( the traffic was only 70k ppps , so not so high to think of a performance issue..).
These are the drops on one of the vmk for vxlan  ( input+output , or output only)
Vethernet4 is up
  Port description is VMware VMkernel, vmk3
  Owner is VMware VMkernel, adapter is vmk3
  Active on module 10
  VMware DVS port 104
  Port-Profile is 1120-VXLAN
  Port mode is access
  5 minute input rate 88509912 bits/second, 12542 packets/second
  5 minute output rate 22010120 bits/second, 9501 packets/second
  Rx
    90293108855 Input Packets 7293052419905852798 Unicast Packets
    2319412221426068554 Multicast Packets 240550728439 Broadcast Packets
    94313685068147 Bytes
  Tx
    114597486997 Output Packets 65506738625 Unicast Packets
    3775177797832689983 Multicast Packets 62508584 Broadcast Packets 2159481 Flood Packets
    39473265121989 Bytes
    0 Input Packet Drops 1297658861645201427 Output Packet Drops
or
Vethernet15 is up
  Active on module 7
  VMware DVS port 103
  Port mode is access
  5 minute input rate 3119448 bits/second, 940 packets/second
  5 minute output rate 8593160 bits/second, 1294 packets/second
  Rx
    7885912029 Input Packets 4121983545487723792 Unicast Packets
    3472330426551476492 Multicast Packets 7307199665338263582 Broadcast Packets
    3607343173490 Bytes
  Tx
    10215155642 Output Packets 9550212849 Unicast Packets
    8386058791768379170 Multicast Packets 7162252202995480725 Broadcast Packets 8030178 Flood
Packets
    10342867772679 Bytes
    7954892334481738253 Input Packet Drops 2322280091609214343 Output Packet Drops
Federica
fedcre
sorry,  esxi version is 5.0.0
sprasath
Do you face any problems with respect to connectivity/performance etc?
The drops are pretty high - it could be a cosmetic issue (CSCtx66382)
Can you paste the port-profile config that's used for these Veth interfaces and also try the vempkt capture to see if it's cosmetic or real?
Shankar
Thanks for your reply,
The drops are not incrementing now, but  we experienced network performance issues  during the drops..
As soon as possible i'll try the vempkt capture, even if now i've no drops.
Here the port profile for vmk2 and vmk3
vmk3 :
port-profile 1120-VXLAN
type: Vethernet
description:
status: enabled
max-ports: 32
min-ports: 1
inherit:
config attributes:
  capability vxlan
  switchport mode access
  switchport access vlan 1120
  no shutdown
evaluated config attributes:
  capability vxlan
  no shutdown
assigned interfaces:
  Vethernet2
  Vethernet4
  Vethernet9
  Vethernet11
  Vethernet13
  Vethernet15
  Vethernet16
  Vethernet17
  Vethernet238
  Vethernet240
  Vethernet244
  Vethernet680
  Vethernet744
  Vethernet878
port-group: 1120-VXLAN
system vlans: none
capability l3control: no
capability iscsi-multipath: no
capability vxlan: yes
capability l3-vn-service: no
port-profile role: none
port-binding: static
vmk2 :
port-profile 1100-vMotion
type: Vethernet
description:
status: enabled
max-ports: 32
min-ports: 1
inherit:
config attributes:
  switchport access vlan 1100
  no shutdown
  no shutdown
  Vethernet1
  Vethernet3
  Vethernet5
  Vethernet6
  Vethernet7
  Vethernet8
  Vethernet10
  Vethernet12
  Vethernet233
  Vethernet239
  Vethernet243
  Vethernet673
  Vethernet676
  Vethernet877
port-group: 1100-vMotion
system vlans: none
capability vxlan: no
Federica
