X.25 problem
abekeris
Level 2
Level 2
We are triyng to use X.25 but in the IBM 3745 we do not see the packets...the sh debug x25 output is:
[172.29.11.254,13554/172.17.2.253,1998]: XOT I P/Inactive Call (27) 8 lci 1
From (9): 368104980 To (8): 36111111
Facilities: (6)
Packet sizes: 128 128
Window sizes: 2 2
Call User Data (7): 0xC3010000 (qllc)
Serial0/1: X.25 O R1 Call (21) 8 lci 1000
Facilities: (0)
Serial0/1: X.25 I R1 Clear (5) 8 lci 1000
Cause 147, Diag 88 (DTE:Local procedure error/Unknown diagnostic)
[172.29.11.254,13554/172.17.2.253,1998]: XOT O P3 Clear (5) 8 lci 1
[172.29.11.254,13554/172.17.2.253,1998]: XOT I P6 Clear Confirm (3) 8 lci 1
Serial0/1: X.25 O R1 Clear Confirm (3) 8 lci 1000
and the config. is as folows:
x25 routing
x25 route .* interface serial0/1
interface Serial0/1
bandwidth 64
no ip address
encapsulation x25 dce
no ip mroute-cache
x25 ltc 1000
x25 htc 1399
clockrate 64000
end
I cannot see what is happening...in another system is working with the same configuration.
Can someone help me ?
oerkan
Level 2
Level 2
Hi Algis,
Could you please describe the end to end topology ? Is the dlsw involved?
Hakan.
Thanks, but finaly was a misstake in the x25 route.
paul.werner
Level 3
Level 3
Where are your mapping statements? Is this a complete config?
