Aleksandar Vidakovic
Update (March 2018)
This document was written at the time when 5.3.4 was about to be released. Hence the SW recommendation for BNG deployment has changed. Please refer to https://supportforums.cisco.com/t5/service-providers-documents/ios-xr-release-strategy-and-deployment-recommendation/ta-p/3165422.
The supported BNG scale specified in this document stands for all 32-bit (aka Classic) IOS XR releases, regardless of the line card generation (Typhoon, Tomahawk) or RSP generation (RSP440-SE, RSP880-SE) because the limit is imposed by the max memory that a process can address. Higher BNG scale requires the 64-bit (aka Enhanced) IOS XR, which also implies Tomahawk and RSP880-SE.
Introduction
The purpose of this document is to share the information about the BNG scale tested within the System Integration Testing (SIT) cycle of IOS XR releases 5.2.4 to 5.3.4 on Cisco ASR9000 platform. This is not the only profile in which BNG was tested at Cisco.
The scalability maximums for individual features may be higher than what is specified in this profile. The BNG SIT profile is provides for a multi-dimensional view of how features perform and scale together. The results in this document closely tie with the setup utilised for this profile. The results may vary depending upon the deployment and optimizations tuned for the convergence.
IOS XR release 5.2.4 is the suggested release for deploying BNG on the ASR9000 platform (until the XR release 5.3.3 is available).
IOS XR release 5.3.4 was posted on October 7th 2016. The XR release 5.3.4 is the Cisco suggested release for all BNG deployments. If your deployment requires features not supported yet in 5.3.4, please reach out to your account  team for recommendation. The scale numbers for 5.3.4 are identical to those from 5.2.4. The difference between these releases is in the supported features and level of BNG hardening cycles that we at Cisco have completed.
Note: starting with XR release 5.3.4 you can use RSP880 in BNG deployments on asr9k. The scale remains the same because the scale is dictated by line card capabilities. The supported BNG scale will increase with the introduction of BNG support on Tomahawk generation line cards.
Feature And Scale Under Test
BNG With MSE (RP based subscribers)
Scale parameter Scale
Access ports bundle GigE/TenGigE
Number of members in a bundle 2
uplink ports TenGige
Scale - PPP session PTA 64k (Without any Other BNG Sessions)
Scale - PPP Sessions L2TP 64k (Without any Other BNG Sessions)
Scale - IPv4 Sessions 64k (Without any Other BNG Sessions)
Scale - PPP v6 session 64k (Without any Other BNG Sessions)
Scale - IP v6 Session 64k (Without any Other BNG Sessions)
Scale - Dual-Stack Session 32k (Without any Other BNG Sessions)
Sessions Per Port 8k/32k
Sessions Per NPU 32k
Sessions Per Line Card 64k
Number of classes per QoS policy 8
Total number of unique QoS policies 50
Number of sub-interfaces 2k
Number LI taps 100
Number CPLs 50
Session QoS Ingress: Policing
Egress: Hierarchical QoS; Model F with 3 queues per session
Number IPv4 ACLs 50
Number ACEs per IPv4 ACL 100
Number IPv6 ACLs 50
Number ACEs per IPv6 ACL 100
Number IGP routes 10k
Number VRFs for subscribers 100
Number BGP routes 30k
Number VPLS 3000
Number VPWS 2000
Number MAC addresses 2000
Number of sessions with multicast receivers 8000
AAA Accounting Start-Stop every 10min
Interim
Service Accounting 64k + 2 services
BNG over Satellite 32k
CPS rate 80 calls per second
CoA 40 requests per second
DHCP (proxy or server) 60 requests per second
BNG Only (RP based subscribers)
Scale - PPP session PTA 128k (Without any Other BNG Sessions)
Scale - IPv4 Sessions 128k (Without any Other BNG Sessions)
DS PPPoE 64k (Without any Other BNG Sessions)
Static Session 8k (Without any Other BNG Sessions)
Routed Subscribers 32k (Without any Other BNG Sessions)
Service Accounting 64K with 2 Services , 24 with 3 Services
Routed Pkt Triggered subscriber IPv4/IPv6 64k
CPU Utilisation (RP based subscribers; 128k IPoEv4)
HW Type A9K-RSP-440-SE MOD80-SE
Role RSP Subscriber facing line card
Major features Total of 128k RP based IPoEv4 or PPPoE subscribers Data plane
CPU steady state 14% 10-14%
CPU peak 60-70% 50-60%
Top processes lpts_pa prm_server_ty
iedged qos_ma_ea
ppp_ma/dhcpd prm_ssmh
ifmgr netio
CPU Utilisation (RP based subscribers; 64k Dual-Stack)
Major features Total of 64k RP based IPoE or PPPoE subscribers Data plane
CPU peak 40-50% 30-40%
iedged qos_ma_ea
ppp_ma/dhcpd prm_ssmh/ipv6_nd
ifmgr/ipv6_nd netio
BNG Only (LC based subscribers)
Access ports GigE/TenGigE
Uplink ports GigE/TenGigE
Scale - PPP session PTA 256k (Without any Other BNG Sessions)
Scale - IPv4 Sessions 256k (Without any Other BNG Sessions)
Scale - PPP v6 session 128k (Without any Other BNG Sessions)
Scale - IP v6 Session 128k (Without any Other BNG Sessions)
DS PPPoE 128k (Without any Other BNG Sessions)
CPU Utilisation (LC based subscribers; 256k IPv4 Sessions)
Major features LC based IPoE or PPPoE Subscribers (256k) LC based Subscribers, Control and Data plane (64K per LC)
CPU steady state 10% 10-14%
CPU peak 10% 80-90%
Top processes dhcpv6/dhcp prm_server_ty
iedged/ipv4_rib dhcpv6/dhcp
ppp_ma/dhcpd iedged
  ppp_ma
  qos_ma_ea
PWHE With BNG Only (RP based subscribers)
Generic interafce list members Bundle, GigE/TenGigE
PW Scale 1k
References
r.maharjan
Hi Xander,
Recently I am pushing ASR9k to wherever possible as it is so much beautiful to work with.
Currently I am deploying BNGs on ASR9010 and ASR9006 where I am using single MOD80-SE with 2 of 4x10G MPA cards. I need your suggestion on how should I deploy as MOD80 has 2 NPs and subscriber limit is 32K per NP. I have some QinQ vlans where one inner vlan got subscribers above 10K. I am seeing docs where it is saying one vlan supports 8k max only. Also I will be using Bundle interfaces hence how should the members be binded? I am planning with 2x10G for LAN and 2x10G WAN from each MPA. Please suggest me if I am going right. Also if I bind 4x10G of one MPA for subscribers and other 4x10G for WAN, will it create issues for max subscriber support? As per your doc each NP can only go 32k.
Hope you would suggest me with best way I could go with to support max sessions and with Bundling.
Raaz
smailmilak
Level 4
Level 4
Hi Raaz,
If you don't want to burn NPU's you should not add multiple NPU's into one BE. You should connect the links like in my fancy illustration.
If you connect the links like that you will get 64K sessions. If you connect two NPU's into one BE you will get "only" 32K sessions.
You can use the same BE for WAN links, just use subinterfaces.
Xander or Aleksander will correct me if I am wrong about that.
Be very cautious though, adding ports from the same NP to a bundle will consume the amount of queues times the amount of bundle member ports. Since BNG scaling is multidimensional, both session count, queue count, policer count etc has to be taken into account.
In the above scenario, using HQoS, each bundle-ether will use up its share of 32K parent queues with only 16K subscribers each.
r.maharjan
Hi Smail, Thank you very much for your suggestion. I have concluded on same and I found your same suggestion on another topic too. Xander/Aleksander and you helping so lot on understanding/deployment on BNG boxes. These docs and discussions have made me possible to deploy/demo so many boxes. Thumbs up to you guys.
hi Raaz,
Smail and Fredrik are both raising valid points.
If you need the QoS policy on subscriber interfaces to only police the traffic, Smail's recommendation stands.
If you need queuing/shaping on subscriber interfaces, Fredrik's recommendation stands. On bundles the QoS policy is replicated per member. If both members are on the same NP you are cutting in half the available QoS resources.
/Aleksandar
puddingtech
Ok so 9001-S should handle 64k subs as its all on the RSP via PPPoE (using bundle) and using GEORED for redundancy.
We're applying avpairs via radius to apply Qos Policing based on a bunch of policy maps for example ingress 2mbit/egress 10mbit example below
policy-map 2048kb -- police rate 2048 kbps burst 384 kbytes peak-rate 3072 kbps peak-burst 768 kbytes
policy-map 40960kb -- police rate 40960 kbps burst 7680 kbytes peak-rate 61440 kbps peak-burst 15360 kbytes
so when a sub connects I get on the subscriber interface policy map....
Bundle-Ether100.48.pppoe32 input: 2048kb
Bundle-Ether100.48.pppoe32 output: 40960kb
We're currently just using static routes but will enable ospf to distribute the routes from the SRG
So my question is based on the above QOS and pppoe setup and the fact we're on a 9001-S, the plan being to have 2x10G LAN and 2x10G WAN, with SRG to the secondary unit... Will we be able to get the full 20gigabit + 64k subs (or will we atleast be able to handle say 16k subs) I'm a bit confused how QOS affects the total number of pppoe subscribers we can handle per box.
xthuijs
hi cchance01, yup you're fine with 64k subs, can be lc based or rsp based (bundle) and using geored. however the 9001-S has only one npu enabled, so then you are limited to 32k subs (32k sub per npu is the hard limit today).
the number of subs would not affect the pps performance so you can get 40G through the box as you desire. probably not at 64byte packets, but with imix it should.
xander
gofagufi1
We need to achieve the below contention ratios
Mbps
GUARANTEED Mbps-FIBRE  LITE
NUMBER OF USERS
                            6
20
             2,6
                            8
40
             4,0
On the uplink from the BNG going up to the CORE is it possible to have sub interfaces for each of the 4 profiles above i.e. 5Mbps,10Mbps,20Mbps and 40Mbps and then cap each of the uplinks to something like this:
5Mbps customers------Uplink capped to 50Meg meaning that we can have a maximum of 10 customers before they start to experience anything less than the Max bandwidth stipulated. And we can have a maximum of about 80 users for that profile each experiencing 1,1.
10MBPS customers-----Uplink capped to 100Meg meaning that we can have a maximum of 10 customers before they start to experience anything less than the Max bandwidth stipulated. And we can have a maximum of about 60 users for that profile each experiencing 1.7.
20 MBPS customers---- Uplink capped to 200Meg meaning that we can have a maximum of 10 customers before they start to experience anything less than the Max bandwidth stipulated. And we can have a maximum of about 80 users for that profile each experiencing 2.6.
40 MBPS customers---- Uplink capped to 400Meg meaning that we can have a maximum of 10 customers before they start to experience anything less than the Max bandwidth stipulated. And we can have a maximum of about 1000 users for that profile each experiencing 4.0.
And then have some form of policy based routing to direct the different traffic profiles to the different respective links.
AS the users in each profile increase there will be some manual intervention to slightly increase the uplink capped bandwidth.
Is this possible?or kindly Suggest an alternative way that could work
Hello Alex,
It would be nice if you could provide updated scale numbers for Tomahawk LCs, specifically the Powerglide ones. What happens with 24x10G Powerglide which has only one NPU? Are we limited to 32K per LC? Do we still have the QoS restrictions that support 8K per port?
Also I'm a bit concerned with the "The XR release 5.3.4 is the Cisco suggested release for all BNG deployments". Using Powerglide you have no choice other than 6.x. Would you change your BNG recommendation or should we avoid Powerglide?? :-)
George
mikebrsnet
Hello, based on the post of smailmilak,  I want to investigate the following scenario. I have a single  chassis with 2 x MOD80 filled with 4xMPA-4x10G (two in each MOD80) and The Chassis will be connected Dual Home to two PEs with a  license for total 64k subs. In case a mod80 fails we will continue to have 64k subs ?
xthuijs
hi mike,
yes that is possible. if you make bundles between the 2 LC's, you can carry 64k sessions, 32k per npu and have bundle redundancy between
the 2 lc's.
xander
Hi Aleksandar, Xander,
Hope you are both doing fine!
I would like to ask you if the scalability charts are somehow affected if we enable egress queueing in a part of the sessions.
To be more specific, we are interested in LC (MOD80-SE) based dual-stack PPPoE sessions.
Do the max values of 64K per LC/128K per chassis get affected/reduced if we enable egress queueing in a part of them and if yes, how can we calculate the max supported values for this case?
Best Regards,
Dimitris
xthuijs
hey dimitris,
adding qos doesnt affect subscriber scale as such. as long as you stay within the number of unique pmaps per LC (10k) and don't exhaust the number of queues per NP (512k).
cheers!
xander
Hey Xander,
Quick as always :) Thanks!
So, if I am not mistaken, we don't expect any scaling issues in the following setup, even if we apply the policy to all 64K sessions, right?
  • 2 x A9K-RSP440-SE
  • 1 x A9K-MOD80-SE
  • 64K LC DS PPPoE sessions
policy-map PARENT-POLICY
 class class-default
  service-policy CHILD-POLICY
  shape average 20 mbps
 end-policy-map
policy-map CHILD-POLICY
 class CHILD-CLASS
  bandwidth remaining percent 30
 class class-default
 end-policy-map
Dimitris
xthuijs
hi Dimitris :) yeah this is bread and butter bng, no problem with that qos policy!
you can have 8 shaped classes per policy and you’re also well within that!
cheers!
xander
