on 06-23-2013 08:38 AM
Layer 2 Virtual Private Network (L2VPN) emulates the behavior of a LAN across an L2 switched, IP or MPLS-enabled IP network, allowing Ethernet devices to communicate with each other as they would when connected to a common LAN segment. Point-to-point L2 connections are vital when creating L2VPNs.
As Internet service providers (ISPs) look to replace their Frame Relay or Asynchronous Transfer Mode (ATM) infrastructures with an IP infrastructure, there is a need to provide standard methods of using an L2 switched, IP or MPLS-enabled IP infrastructure. These methods provide a serviceable L2 interface to customers; specifically, to provide virtual circuits between pairs of customer sites.
Building a L2VPN system requires coordination between the ISP and the customer. The ISP provides L2 connectivity; the customer builds a network using data link resources obtained from the ISP. In an L2VPN service, the ISP does not require information about the customer's network topology, policies, routing information, point-to-point links, or network point-to-point links from other ISPs.
There are two fundamentally different kinds of Layer 2 VPN service that a service provider could offer to a customer: Virtual Private Wire Service (VPWS) and Virtual Private LAN Service (VPLS). There is also the possibility of an IP-only LAN-like Service (IPLS).
A VPWS is a VPN service that supplies an L2 point-to-point service. As this is a point-to-point service, there are very few scaling issues with the service as such. Scaling issues might arise from the number of end-points that can be supported on a particular PE.
A VPLS is an L2 service that emulates LAN service across a Wide Area Network (WAN). With regard to the amount of state information that must be kept at the edges in order to support the forwarding function, it has the scaling characteristics of a LAN. Other scaling issues might arise from the number of end-points that can be supported on a particular PE.
Discovery refers to the process of finding all the PEs that participates in a given VPLS/VPWS instance. A PE either can be configured with the identities of all the other PEs in a given L2VPN service or can use some protocol to discover the other PEs. The later is called auto-discovery.
The former approach is fairly configuration-intensive, especially since it is required that the PEs participating in a given VPLS is fully meshed (i.e., that every PE in a given VPLS establish pseudowires to every other PE in that VPLS). Furthermore, when the topology of a VPLS changes (i.e., a PE is added to, or removed from, the VPLS), the VPLS configuration on all PEs in that VPLS must be changed.
In the auto-discovery approach, each PE "discovers" which other PEs are part of a given VPLS/VPWS by means of some protocol, in this case BGP. This allows each PE's configuration to consist only of the identity of the VPLS/VPWS instance established on this PE, not the identity of every other PE in that VPLS/VPWS instance -- that is auto-discovered. Moreover, when the topology changes, only the affected PE's configuration changes; other PEs automatically find out about the change and adapt.
Conventional VPLS implementation requires manual configuration of each neighbor (VPLS PE) in the VPLS domain. When a new PE is added or removed from the VPLS domain, manual configuration of each PE in the VPLS domain is required.
Manual configuration changes add operational costs and increase the chance of network mis-configuration.
VPLS Auto Discovery eliminates the need to manually provision a VPLS neighbor. VPLS auto discovery automatically detects when new PEs are added or removed from the VPLS domain.
Auto-discovery by nature requires the information to be distributed to all members of a VPN - multipoint mechanism - which BGP is well suited for.
BGP is also used for signaling to exchange label bindings and signal MTU and state changes. Although LDP is better suited for signaling between two endpoints, it is needed for interoperability with other vendors.
There is no true auto-discovery in VPWS as it is in VPLS. In VPWS, to connect CEs, user has to explicitly configure at each PE. All what is discovered in VPWS is the existence of other PEs.
There are two primary functions of the VPLS control plane: auto-discovery, and setup and teardown of the pseudowires that constitute the VPLS, often called signaling. Both of these functions are accomplished with a single BGP Update advertisement.
When the L2VPN address-family (AF) and VPLS/VPWS subsequent address-family (SAF) are configured, BGP will connect to L2VPN to receive configured VPLS bridge domains. In the case of distributed BGP and the presence of multiple BGP speakers, L2VPN still communicates with one active BGP instance only. Therefore, BGP distribution is completely hidden from L2VPN.
When a VPLS Bridge domain is configured with BGP auto-discovery and signaling enabled, BGP needs to distribute NLRI for the VPLS bridge domain with the PE as the BGP next-hop and appropriate VE-ID. Additionally, the VPLS is associated with one or more BGP export Route Targets (RTs) that are also distributed (along with NLRI). VPLS SAFI NLRI uses AFI = 25 and SAFI = 65. The keywords "l2vpn" and "vpls-vpws" will be introduced to represent AF and SAF respectively in the BGP configuration.
If a PE receiving VPLS NLRIs is configured with the VPLS associated with a particular import RT, it can then import all the NLRIs tagged with the same RT. Generic BGP RPL policies for RT filtering will be supported for the VPLS/VPWS SAFI. No specific NLRI policy will be added for VPLS/VPWS SAFIs.
The NLRI format for VPLS BGP-AD & BGP Signaling is shown in the diagram below:
Length (2 octets) |
Route Distinguisher (8 octets) |
VE ID (2 octets) |
VE Block Offset (2 octets) |
VE Block Size (2 octets) |
Label Base (3 octets) |
Figure 1: NLRI format for VPLS with BGP Auto-discovery and Signaling
PE1:
PE1# show l2vpn discovery bridge-domain
Service Type: VPLS, Connected
List of VPNs (1 VPNs):
Bridge group: bg1, bridge-domain: bd1, id: 0
List of Local Edges (1 Edges):
Local Edge ID: 3, Label Blocks (1 Blocks)
Label base Offset Size Time Created
16015 1 10 01/24/2009 16:23:27
List of Remote Edges (1 Edges):
Remote Edge ID: 5, NLRIs (1 NLRIs)
Label base Offset Size Peer ID Time Created
16120 1 10 1.1.1.1 01/24/2009 16:23:46
PE1# show l2vpn bridge-domain detail
VFI vf1
VPN-ID: 100, Auto Discovery: BGP, state is Provisioned (Service Connected)
Route Distinguisher: (auto) 3.3.3.3:32770
Import Route Targets:
2.2.2.2:100
Export Route Targets:
2.2.2.2:100
Signaling protocol: BGP
Local VE-ID: 3 , Advertised Local VE-ID : 3
VE-Range: 10
PW: neighbor 1.1.1.1, PW ID 100, state is up (established)
Encapsulation MPLS, Auto-discovered (BGP), protocol BGP
MPLS Local Remote
Label 16019 16122
MTU 1500 1500
Control word disabled disabled
PW type VPLS VPLS
VE-ID 3 5
PE1# show bgp l2vpn vpls
BGP router identifier 3.3.3.3, local AS number 100
BGP generic scan interval 60 secs
BGP table state: Active
Table ID: 0x0
BGP main routing table version 898
BGP NSR converge version 3
BGP NSR converged
BGP scan interval 60 secs
Status codes: s suppressed, d damped, h history, * valid, > best
i - internal, S stale
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Rcvd Label Local Label
Route Distinguisher: 1.1.1.1:32775
*>i5:1/32 1.1.1.1 16120 nolabel
Route Distinguisher: 3.3.3.3:32770 (default for vrf bg1:bd1)
*> 3:1/32 0.0.0.0 nolabel 16015
Processed 3 prefixes, 3 paths
PE2:
PE2# show l2vpn discovery bridge-domain
Local Edge ID: 5, Label Blocks (1 Blocks)
16120 1 10 01/24/2009 16:03:26
Remote Edge ID: 3, NLRIs (1 NLRIs)
16015 1 10 3.3.3.3 01/24/2009 16:03:26
PE2# show l2vpn bridge-domain detail
VFI vf1
Route Distinguisher: (auto) 1.1.1.1:32775
2.2.2.2:100
2.2.2.2:100
Local VE-ID: 5 , Advertised Local VE-ID : 5
VE-Range: 10
PW: neighbor 3.3.3.3, PW ID 100, state is up ( established )
MPLS Local Remote
Label 16122 16019
MTU 1500 1500
PW type VPLS VPLS
VE-ID 5 3
PE2# show bgp l2vpn vpls
BGP router identifier 1.1.1.1, local AS number 100
Table ID: 0x0
BGP main routing table version 802
BGP NSR converge version 7
BGP NSR converged
Route Distinguisher: 1.1.1.1:32775 (default for vrf bg1:bd1)
*>i3:1/32 3.3.3.3 16015 nolabel
*> 5:1/32 0.0.0.0 nolabel 16120
A third PE (PE3) is added to the same VPLS domain with BGP AD & signaling.
Following is the L2VPN config for PE3:
List of Remote Edges (2 Edges):
Remote Edge ID: 7, NLRIs (1 NLRIs)
16145 1 10 5.5.5.5 01/24/2009 16:40:32
VFI vf1
2.2.2.2:100
2.2.2.2:100
VE-Range: 10
PW: neighbor 1.1.1.1, PW ID 100, state is up ( established )
MPLS Local Remote
Label 16019 16122
MTU 1500 1500
PW type VPLS VPLS
VE-ID 3 5
PW: neighbor 5.5.5.5, PW ID 100, state is up ( established )
MPLS Local Remote
Label 16021 16147
MTU 1500 1500
PW type VPLS VPLS
VE-ID 3 7
Table ID: 0x0
BGP NSR converged
*>i7:1/32 7.7.7.7 16145 nolabel
Route Distinguisher: 5.5.5.5:32780
Processed 5 prefixes, 5 paths
Similar to VPLS, two primary functions of the VPWS control plane is: auto-discovery, and setup and teardown of the pseudowires that constitute the VPWS to build a full mesh of CEs, often called signaling. Both of these functions are accomplished with a single BGP Update advertisement.
When a VPWS cross-connect is configured with BGP auto-discovery and signaling enabled, BGP needs to distribute NLRI for the xconnect with the PE as the BGP next-hop and appropriate CE-ID. Additionally, the cross-connect is associated with one or more BGP export Route Targets (RTs) that are also distributed (along with NLRI). VPLS SAFI NLRI uses AFI = 25 and SAFI = 25 [5]. The keywords "l2vpn" and "vpls-vpws" will be introduced to represent AF and SAF respectively in the BGP configuration.
The configured attributes are similar to VPLS with the following differences:
• CE-IDs instead of VE-IDs
• ce-id-range instead of ve-id-range.
• ACs are configured with remote CE-IDs. This association is save in L2VPN database and used to establish P2P xconnects.
If a PE receiving VPWS NLRIs is configured with the cross-connect associated with a particular import RT, it can then import all the NLRIs tagged with the same RT.
The NLRI is in the format shown in diagram below:
Length (2 octets) |
CE ID (2 octets) |
CE Block Offset (2 octets) |
CE Block Size (2 octets) |
Status Vector (SubTLV) |
Figure 2: NLRI format for VPWS BGP Auto-discovery and Signaling
PE1:
PE1# show l2vpn discovery xconnect
Service Type: VPWS, Connected
XC Group: gr1, MP2MP mp1
Local Edge ID: 1, Label Blocks (1 Blocks)
16030 1 10 01/24/2009 21:23:04
Status Vector: 9f ff
Remote Edge ID: 2, NLRIs (1 NLRIs)
16045 1 10 1.1.1.1 01/24/2009 21:29:35
Status Vector: 7f ff
16060 1 10 1.1.1.1 01/24/2009 21:29:35
PE1# show l2vpn xconnect mp2mp detail
Group gr1, MP2MP mp1, state: up
VPN ID: 100
VPN MTU: 1500
L2 Encapsulation: VLAN
Auto Discovery: BGP, state is Advertised (Service Connected)
2.2.2.2:100
2.2.2.2:100
Signaling protocol:BGP
CE Range:10
Group gr1, XC mp1.1:2, state is up; Interworking none
Local CE ID: 1, Remote CE ID: 2, Discovery State: Advertised
AC: GigabitEthernet0/1/0/1.1, state is up
Type VLAN; Num Ranges: 1
VLAN ranges: [1, 1]
MTU 1500; XC ID 0x2000013; interworking none
PW: neighbor 1.1.1.1, PW ID 65538, state is up ( established )
PW class not set, XC ID 0x2000013
MPLS Local Remote
Label 16031 16045
MTU 1500 1500
Control word enabled enabled
PW type Ethernet VLAN Ethernet VLAN
CE-ID 1 2
Group gr1, XC mp1.1:3, state is up; Interworking none
Local CE ID: 1, Remote CE ID: 3, Discovery State: Advertised
AC: GigabitEthernet0/1/0/1.2, state is up
VLAN ranges: [2, 2]
MTU 1500; XC ID 0x2000014; interworking none
PW: neighbor 1.1.1.1, PW ID 65539, state is up ( established )
PW class not set, XC ID 0x2000014
MPLS Local Remote
Label 16032 16060
MTU 1500 1500
CE-ID 1 3
PE1# show bgp l2vpn vpws
Table ID: 0x0
BGP main routing table version 913
BGP NSR converged
*>i2:1/32 1.1.1.1 16045 nolabel
*>i3:1/32 1.1.1.1 16060 nolabel
Route Distinguisher: 3.3.3.3:32770 (default for vrf gr1:mp1)
*> 1:1/32 0.0.0.0 nolabel 16030
PE2:
PE2# show l2vpn discovery xconnect
List of Local Edges (2 Edges):
Local Edge ID: 2, Label Blocks (1 Blocks)
16045 1 10 01/24/2009 21:09:14
16060 1 10 01/24/2009 21:09:14
Remote Edge ID: 1, NLRIs (1 NLRIs)
16030 1 10 3.3.3.3 01/24/2009 21:09:16
PE2# show l2vpn xconnect mp2mp detail
VPN ID: 100
VPN MTU: 1500
2.2.2.2:100
2.2.2.2:100
CE Range:10
Group gr1, XC mp1.2:1, state is up; Interworking none
Local CE ID: 2, Remote CE ID: 1, Discovery State: Advertised
AC: GigabitEthernet0/1/0/2.1, state is up
VLAN ranges: [1, 1]
MTU 1500; XC ID 0x2000008; interworking none
PW: neighbor 3.3.3.3, PW ID 131073, state is up ( established )
PW class not set, XC ID 0x2000008
MPLS Local Remote
Label 16045 16031
MTU 1500 1500
CE-ID 2 1
PE2# show bgp l2vpn vpws
Table ID: 0x0
BGP main routing table version 819
BGP NSR converged
Route Distinguisher: 1.1.1.1:32775 (default for vrf gr1:mp1)
*>i1:1/32 3.3.3.3 16030 nolabel
*> 2:1/32 0.0.0.0 nolabel 16045
*> 3:1/32 0.0.0.0 nolabel 16060
Processed 4 prefixes, 4 paths
L2VPN discovery not working
Check the router bgp configs, as sample configs shown below:
RP/0/RSP1/CPU0:PE1#show run router bgp
router bgp 100
nsr
bgp router-id 2.2.2.2
bgp graceful-restart
address-family l2vpn vpls-vpws
neighbor 3.3.3.3
remote-as 100
update-source Loopback0
RP/0/RSP1/CPU0:PE1#
RP/0/RSP0/CPU0:PE2#show run router bgp
router bgp 100
nsr
bgp router-id 3.3.3.3
neighbor 2.2.2.2
remote-as 100
RP/0/RSP0/CPU0:PE2#
Check the configs for BGP AD under l2vpn BD :
-> Check the VPN-ID matches with the other side PE
-> Check the ve-id is different from the other side PE
-> Check the rd, generally it will be auto
-> Check the signalling protocol configured the same correctly on both the ends
Sample Cfgs :
On PE1 :
l2vpn
bridge group bg1
bridge-domain bg1_bd1
interface PW-Ether2.1
interface GigabitEthernet0/1/1/10.1
vfi bgp_ad1
vpn-id 1001
autodiscovery bgp
rd auto
route-target 10.1.1.1:1
signaling-protocol bgp
ve-id 1001
On PE2 :
l2vpn
bridge group bg1
interface GigabitEthernet0/2/1/11.101
vfi bgp_ad1
vpn-id 1001
autodiscovery bgp
rd auto
ve-id 2001
If still the VFI is down
--> Start from IGP Neighborship
RP/0/RSP1/CPU0:PE1#show ospf neighbor
* Indicates MADJ interface
Neighbors for OSPF 100
Neighbor ID Pri State Dead Time Address Interface
3.3.3.3 1 FULL/DR 00:00:35 30.2.1.2 Bundle-Ether3
Neighbor is up for 23:38:15
3.3.3.3 1 FULL/DR 00:00:38 30.1.1.2 TenGigE0/1/0/1
Neighbor is up for 1d22h
4.4.4.4 1 FULL/DR 00:00:35 60.1.1.2 GigabitEthernet0/1/1/9
Total neighbor count: 3
RP/0/RSP1/CPU0:PE1#
--> Then check the BGP l2vpn Neighbors
RP/0/RSP1/CPU0:PE1#show bgp l2vpn vpls summary
BGP router identifier 2.2.2.2, local AS number 100
Non-stop routing is enabled
Table ID: 0x0 RD version: 0
BGP main routing table version 1
BGP NSR Initial initsync version 1 (Reached)
BGP is operating in STANDALONE mode.
Process RcvTblVer bRIB/RIB LabelVer ImportVer SendTblVer StandbyVer
Speaker 1 1 1 1 1 1
Neighbor Spk AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down St/PfxRcd
3.3.3.3 0 100 4 4 1 0 0 00:01:21 0
RP/0/RSP1/CPU0:PE1#
--> Check the BD Detail for more details when the PW is down.
RP/0/RSP1/CPU0:PE1#show l2vpn bridge-domain bd-name bg1_bd1
Legend: pp = Partially Programmed.
Bridge group: bg1, bridge-domain: bg1_bd1, id: 20, state: up, ShgId: 0, MSTi: 0
Aging: 300 s, MAC limit: 4000, Action: none, Notification: syslog
Filter MAC addresses: 0
ACs: 2 (2 up), VFIs: 1, PWs: 1 (1 up), PBBs: 0 (0 up)
List of ACs:
Gi0/1/1/10.1, state: up, Static MAC addresses: 0
PE2.1, state: up, Static MAC addresses: 0
List of Access PWs:
List of VFIs:
VFI bgp_ad1 (up)
Neighbor 3.3.3.3 pw-id 1001, state: up, Static MAC addresses: 0
RP/0/RSP1/CPU0:PE1#
List of ACs:
List of Access PWs:
List of VFIs:
VFI bgp_ad1 (up)
RP/0/RSP1/CPU0:PE1#show l2vpn bridge-domain autodiscovery bgp detail
Coupled state: disabled
MAC learning: enabled
MAC withdraw: enabled
MAC withdraw for Access PW: enabled
MAC withdraw sent on: bridge port up
MAC withdraw relaying (access to access): disabled
Flooding:
Broadcast & Multicast: enabled
Unknown unicast: enabled
MAC aging time: 300 s, Type: inactivity
MAC limit reached: no
MAC port down flush: enabled
MAC Secure: disabled, Logging: disabled
Split Horizon Group: none
Dynamic ARP Inspection: disabled, Logging: disabled
IP Source Guard: disabled, Logging: disabled
DHCPv4 snooping: disabled
IGMP Snooping: enabled
IGMP Snooping profile: none
MLD Snooping profile: none
Storm Control: disabled
Bridge MTU: 1500
MIB cvplsConfigIndex: 21
Create time: 26/06/2013 12:36:30 (00:14:13 ago)
No status change since creation
List of VFIs:
VFI bgp_ad1 (up)
VPN-ID: 1001, Auto Discovery: BGP, state is Provisioned (Service Connected) Route Distinguisher: (auto) 2.2.2.2:32768
10.1.1.1:1
10.1.1.1:1
Local VE-ID: 1001 , Advertised Local VE-ID : 1001
VE-Range: 10
PW: neighbor 3.3.3.3, PW ID 1001, state is up ( established )
PW class not set, XC ID 0xc0000414
Source address 2.2.2.2
PW type VPLS, control word disabled, interworking none
Sequencing not set
MPLS Local Remote
Label 289975 16046
MTU 1500 1500
PW type VPLS VPLS
VE-ID 1001 2001
MIB cpwVcIndex: 3221226516
Create time: 26/06/2013 12:37:26 (00:13:18 ago)
Last time status changed: 26/06/2013 12:37:26 (00:13:18 ago)
MAC withdraw messages: sent 0, received 0
Statistics:
packets: received 0, sent 0
bytes: received 0, sent 0
VFI Statistics:
drops: illegal VLAN 0, illegal length 0
RP/0/RSP1/CPU0:PE1#
great document!
Hi, reranti:
If I have a deployment that implements the traditional L3VPN and also L2VPN with BGP-AD/LDP signaling: do I have to consider completely different route-targets for each L3 and L2 VPN?
That is: since the AFI is different for each service, can I repeat RTs for a specific L2 and L3 environment? It's not a requirement, but I'd like to to know if it's possible.
c.
Hi, reranti:
Another question if you find the time. What would be your considerations when trying to put a limit on a VPLS endpoint number? I mean, AFAIC, L3VPN you can handle 1000 termination points (customer CE) without much of a problem. What would be a reasonable number when talking L2VPN?
c.
Within MPLS domain, could I use the same vpn-id more than 1 PE?
that's the way some docs suggest and the way i've implemented it in the field. only thing is it has to be unique within the PE. all PEs that terminate the same VPLS should can use same vpn-id.
http://www.cisco.com/c/en/us/td/docs/routers/crs/software/crs_r4-1/lxvpn/configuration/guide/vc41crs/vc41vpls.html
Hi reranti,
Can you add route-reflector requirements, configs and toubleshooting?
Thanks!
Created 3 years ago and it's still giving off fruit. Great document.Thank you very much.
First of all, Great Document. Now, i've been trying enable VPLS with BGP autodiscovery and BGP signalling between an ASR920 and an ASR9010 (as Route Reflector), i see the BGP l2vpn vpls information being shared between them. I have another ASR9010, the VPLS service work great between these two XRs, but not towards the ASR920 XE router.
When validating the bridge-domain in the ASR920, i can only see information coming from the service-instance, but not from the VFI.
Any Suggestions?
This is the config so far:
ASR9010
bridge group VPLS4761
bridge-domain 2705
interface GigabitEthernet0/1/0/1.2705
vfi VFI2705
vpn-id 2705
autodiscovery bgp
rd 127:2705
route-target 127:2705
ve-id 104
router bgp xxxx
neighbor-group iBGP
route-reflector-client
next-hop-self
ASR920
l2vpn vfi context VFI2705
vpn id 2705
autodiscovery bgp signaling bgp
ve id 113
ve range 100
rd 127:2705
route-target export 127:2705
route-target import 127:2705
route-target export 23456:2705
bridge-domain 2705
member GigabitEthernet0/0/0 service-instance 2705
member vfi VFI2705
router bgp xxxx
neighbor 10.19.0.4 activate
neighbor 10.19.0.4 send-community both
neighbor 10.19.0.4 prefix-length-size 2
neighbor 10.19.0.4 suppress-signaling-protocol ldp
Good Day
Can you explain me when do I use rewrite ingress tag pop 2 symmetric ?
Wilson
Well, this has not really something to do with BGP autodiscovery, the "rewrite ingress tag pop 2 symmetric" is more an option, which you can use in vlan manipulation in terms of flexible matching and rewrite options.
Have a look at the following document, this gives some insights about the possibilities:
https://supportforums.cisco.com/document/85231/understanding-ethernet-virtual-circuits-evc
One of the things that make EVCs so powerful is their flexible matching criteria. EVCs allow us to classify inbound frames in a highly flexible manner based on 1 or more VLAN tags or CoS values. Here are some examples
Configuration | Effect |
encapsulation dot1q 10 | Match the single VLAN tag 10 |
encapsulation dot1q 25 second-dot1q 13 |
Match first VLAN tag 25 and second tag 13 |
encapsulation dot1q any second-dot1q 22 | Match any double tagged frame with a second tag of 22 |
encapsulation dot1q 16 cos 4 |
Match a single tag 16 when it has CoS value 4 |
encapsulation dot1q untagged | Match the native (untagged) VLAN |
encapsulation dot1q default | The catch all class for all traffic not previously classified |
The options here are not exhaustive but just some examples. The other thing to remember about tag matching is that we follow a longest match criteria.
Along with a number of flexible matching options we have numerous tag rewrite options.
rewrite ingress tag pop 1 symmetric | remove the top 802.1q tag |
rewrite ingress tag pop 2 symmetric | remove the top two 802.1q tags |
rewrite ingress tag translate 1-to-1 dot1q 28 symmetric |
remove the top tag and replace it with 28 |
rewrite ingress tag translate 2-to-2 dot1 22 second-dot1q 23 |
remove the top two tags and replace them with 22 and 23 (23 will be the inner tag) |
rewrite ingress tag push dot1q 56 second-dot1q 55 | push two new tags on top of the existing frame. The top tag will be 56; inner tag of 55 |
hi
Its a very good document. Thanks for sharing.
I just wanted to understand how does the MTU propagate with BGP AD implementation of VPLS and VPWS because i dont find any field in the NLRI which could do this. In case of LDP it used to be part of the label mapping message ( PW ID FEC TLV has interface parameters ) between the targeted peers .
regards
Aseem.
thanks for that article. Helped a lot in understanding L2PVN mechanics.
VPLS is clear to me. For VPLS I know of:
RFC 4761 --> defines VPLS with BGP-AD and BGP-SIG
RFC 4762 --> defines VPLS with LDP-SIG
RFC 6074 --> defines (among other stuff) BGP-AD extension for RFC 4762, so it becomes
VPLS with BGP-AD and LDP-SIG
However, if it comes to VPWS things get a little more obscure. I am missing such clear definitions for VPWS as there are for VPLS. When it comes to VPWS people normally do:
Manual Provisioning of LDP-FEC128 Services.
Manual Provisioning of LDP-FEC129 Services.
... but there are extensions to provide BGP-AD for PWE3 --> RFC 6074
Q1: RFC 6074 defines (along with VPLS-AD) VPWS BGP-AD for LDP FEC129 as well.
Is this also supported in IOS-XR, or is the occurence of bgp l2vpn vpls-vpws only for RRF- purposes in terms of VPWS.
Q2: The same mechanism from RFC 4761 is used for VPWS in this article. In which RFC is that documented?
Many Thanks,
Rene
for BGP-signaled L2VPNs this is cover by
Layer2 Info Extended Community
The up to date form can be found here:
https://tools.ietf.org/html/draft-ietf-bess-fat-pw-bgp-01
This should look like L2VPN:19:e:8000 attached to a VPLS Prefix.
| | MTU (dec)
| -> CW+FlowLabel RX/TX (hex)
----> 19 = Encaps VPLS (dec)
Cheers
Why is it giving
AC: GigabitEthernet0/0/0/1, state is unresolved
and the VPLS isn't working
RP/0/0/CPU0:XRV29#show l2vpn bridge-domain detail
Mon Nov 28 15:22:26.468 UTC
Bridge group: 1, bridge-domain: 1, id: 0, state: up, ShgId: 0, MSTi: 0
Flooding:
Bridge MTU: 1500
MIB cvplsConfigIndex: 1
P2MP PW: disabled
Create time: 28/11/2016 12:32:26 (02:50:00 ago)
ACs: 1 (0 up), VFIs: 1, PWs: 1 (1 up), PBBs: 0 (0 up)
List of ACs:
XRV30 running config
router bgp 1
address-family vpnv4 unicast
neighbor 29.29.29.29
remote-as 1
neighbor 31.31.31.31
remote-as 1
l2vpn
bridge group 1
bridge-domain 1
interface GigabitEthernet0/0/0/1
vfi 1
vpn-id 1
autodiscovery bgp
rd auto
route-target 1:1
ve-id 1
XRV31 running configuration
router bgp 1
remote-as 1
neighbor 30.30.30.30
remote-as 1
mpls ldp
XRV29 running configuration
router bgp 1
remote-as 1
remote-as 1
l2vpn
bridge group 1
bridge-domain 1
vfi 1
vpn-id 1
autodiscovery bgp
rd auto
route-target 1:1
ve-id 5
Have you configured GigabitEthernet0/0/0/1 as l2transport?
