RS345P 1:1 NAT
How on earth do we get 1:1 NAT working with the RV345P?? After port forwarding is setup do I have create access rules?
7 Replies 7
 Use static NAT
balaji.bandi
Do you have Public IP range, or you have only 1 IP address provided by ISP ?
Make sure you also check the BLOCK Wan request (enable check box remove that to work) -
https://www.youtube.com/watch?v=FPupQEYTFQc
BB
In this Cisco Tech Talk, we'll discuss how configure a one-to-one Static NAT in a Cisco RV340 series router.
- block wan requests is ENABLED (checked)
- Static NAT table: 192.168.1.114 - 206.248.***.*** Range Length 1 Services (ALL SERVICES) WAN Interface: WAN 2
Have quite a few services setup. In my opinion this is a STATIC NAT configuration. Should we add each of services on it's own line and specific the service, like this:
- Static NAT table: 192.168.1.114 - 206.248.***.*** Range Length 1 Services (Service A) WAN Interface: WAN 2
- Static NAT table: 192.168.1.114 - 206.248.***.*** Range Length 1 Services (Service B) WAN Interface: WAN 2
- Static NAT table: 192.168.1.114 - 206.248.***.*** Range Length 1 Services (Service C) WAN Interface: WAN 2
- Static NAT table: 192.168.1.114 - 206.248.***.*** Range Length 1 Services (Service D) WAN Interface: WAN 2
I am sure you can do Service management -  this few ports like 10-20 i will add manually.
BB
Services have been added manually and forwarded accordingly.
My question is to accomplish 1:1 NAT, on the RV345P: Firewall > STATIC NAT, should I add each of the services individually for 1:1 NAT? As is stands I have ALL SERVICES between PUBLIC and PRIVATE. Should I add individual entries for each service???
That is what i have directed you with the picture :
1. as per i know, you can do range ports
2. I do not see any grouping Services.in one services group.
If range not work for you, then you need to do manually each services(becauuse of the limitration)
Hope that clears.
BB
