SRP527W EOS/EOL
o.melendres
The SRP500 series went out of sale, but is not specified of a replacement product on the EOS/EOL announcement. Does anyone could suggest a replacement product with a similar market position and features?
http://www.cisco.com/en/US/prod/collateral/routers/ps10907/ps10500/end_of_life_notice_c51-728170.html
The main features used on SRP527W are:
ADSL interface
4 port LAN
Wireless LAN
2 FXS ports
SIP agent
QOS for voip
Minimum firewall and VPN
jeffrrod
Level 4
Level 4
Dear Partner,
Thank you for reaching the Small Business Support Community.
Unfortunately none of the Small Business series routers have an integrated xDSL interface, still capable on PPPoE WAN configuration but you would need to connect through a xDSL modem.  For a built in xDSL interface router I suggest you looking at the 800 series ISR routers.
http://www.cisco.com/cisco/web/solutions/small_business/products/routers_switches/index.html
Please do not hesitate to reach me back if there is any further assistance I may help you with.
Kind regards,
Jeffrey Rodriguez S. .:|:.:|:.
Cisco Customer Support Engineer
*Please rate the Post so other will know when an answer has been found.
Jeffrey Rodriguez S. .:|:.:|:. Cisco Customer Support Engineer *Please rate the Post so other will know when an answer has been found.
Hi Octavio,
The Cisco 887V Integrated Services Router would be the best alternative.
http://www.cisco.com/en/US/products/ps10514/index.html
Cindy Toy
Cisco Small Business Community Manager
for Cisco Small Business Products
www.cisco.com/go/smallbizsupport
twitter: CiscoSBsupport
Regards, Cindy If my response answered your question, please mark the response as answered. Thank you!
The Cisco 887V is a good solution. The problem is that the target is a different market segment. The solution costs about 5 times the SRP527W.
The alternative of using a separate ADSL modem could technically work too, but it has some extra management burdens we would like to avoid.
The perfect solution would be in the SRP527W price range,
Thanks for your replies,
Octavio
