almoncad
An Access Control List (ACL) is an ordered list of actions the switch performs one by one. Each action is defined by an Access Control Entry (ACE) which specifies the decisions the ACL must perform. These ACEs can perform tasks such as allowing or denying a specific network portion, or a network protocol. A single ACL can have more than one ACE to accomplished a given task. The Sx200/300 Series Managed Switches can have 512 ACLs and 512 ACEs.
ACLs are of great use in a network since they provide the tools to filter traffic according to the network needs, which makes the network more reliable and efficient.
ACL & ACE Configuration Articles:
MAC Based ACL and ACE Configuration on 300 Series Managed Switches
Configure IPv4-Based Access Lists on the 200/300 Series Managed Switches
IPv6-Based ACL & ACE on 300 Series Managed Switches
Bind Access Control List (ACL) to an Interface on 200/300 Series Managed Switches
Was this information Helpful? Please leave us your feedback.
jialbert
CLI Examples:
time-range Weekend
periodic sat 00:00 to sun 23:59
mac access-list extended MAC
permit 00:00:00:00:10:00 00:00:00:00:00:00 any
ipv6 access-list "v6"
permit ipv6 2001::/64 2003::/64 time-range Weekend
ip access-list extended Server
permit icmp 192.168.1.0 0.0.0.255 172.16.1.0 0.0.0.255 any any
permit tcp 192.168.1.0 0.0.0.255 any 172.16.1.0 0.0.0.255 any
permit ip any any time-range Weekend
interface Port-channel1
service-acl input Server
SG300(config-if)#do sh access
Extended IP access list Server
    permit  icmp 192.168.1.0 0.0.0.255 172.16.1.0 0.0.0.255 type any code any
SG300(config-if)#do sh time-ran
time-range Weekend
periodic Saturday 00:00 to Sunday 23:59
SG300(config-if)#do sh int access
Interface                  ACLs
Po1                Ingress: Server
SG300(config-if)#
almoncad
Thank you
Since1953
I'm using the SG300. Is this the same or similar as MAC Filtering?
In reading how to configure an ACL and ACE, it appears that you can only apply one ACL per interface (i.e., VLAN 1). I have 200+ devices that I want to permit access (and deny all others) however, the ACE will only let me have 31 entries per ACL.
Is there something I'm missing, or is this a limitation of the SG300?
