Jo Kern
Cisco RV340 Series Secure Router
Security License Features and Performance
May 2019
Today, secure networking is imperative for every business, even the smallest one. The RV340 series security routers provides business users with advanced connectivity and secure high-speed access for the growing demand and usage of digital services. The Cisco RV340 Series routers connect small businesses securely to the Internet. The routers protect employees from threats like viruses, network attacks, unwanted content and malicious websites. All that without compromising the online experience. The series consists of 4 models: RV340, RV345, RV345P, and RV340W. The models differ in number of featured switch ports, PoE and WiFi support. More info at www.cisco.com/go/rvrouters
The optional security license described here enables enhanced UTM security features. The router is fully functional without installing a license and will work with full performance and all NAT, Firewall, VPN features are turned on.
Installing the security license enables UTM security features including: Intrusion Prevention, Gateway Anti-virus, Application Identification, Client Identification and Statistics, on-board dynamic Web Security. These features protect your network from attacks from the Internet and at the same allow for setting policies for corporate usage of the Internet by limiting Internet surfing to appropriate site categories and eliminating unwanted network traffic and hence boost employee productivity and overall network performance.
The license utilizes Cisco Software Smart Licensing. See https://software.cisco.com for more info and how to create a Smart Account. With Cisco Software Smart Licensing the license is not bound to a specific serial number of a device but assigned to a user or company account
The licensed security features can be trialed at no cost for 90 days.
 Ordering Information
Type
Product ID
Description
RV Security License
LS-RV34X-SEC-1YR=
Internet security package:
-Dynamic web filter
-Intrusion Prevention
-Gateway Anti Virus
-Application Visibility
-Client Identification and Statistics
Feature Description:
Web security
Dynamic web filtering: Cloud based, more than 80 categories, more than 450 million domains classified
Enables business efficiency and security while connecting to the Internet, allows Internet access policies for end devices and Internet applications to help ensure performance and security.
Identify and Assign policies to Internet applications
500 unique Apps automatically identified
Identify and categorize connected devices and provide detailed statistics on Internet usage
Intrusion Prevention System
IDS/IPS inspects network packets, logs and/or blocks a wide range of network attacks. It delivers increased network availability, faster remediation and comprehensive threat protection. Protocols supported HTTP/FTP/SMTP/POP3/IMAP
Antivirus
Protection from viruses, trojans, spyware and identity theft by inspecting traffic going through the router. Supported: HTTP/FTP/SMTP/POP3/IMAP
Performance:
The router uses a unique hardware acceleration engine.
Connection Rate
Concurrent Connections
HTTP Throughput
FTP Throughput
IPS & AntiVirus & App ID
4000/s
40000
980Mbps
950Mbps
Data above with logs turned off.
Martin Aleksandrov
 Another great security improvement in Cisco best-in-class SMB router! Excellent operating performance and functionalities ratio.
RYN0
What AV engine and IPS are used in the back-end of this device with the security subscription? If it uses AMP and Snort/Sourcefire, that would be really nice.
Jo Kern
Hi, it uses Lionic IPS and AV
www.lionic.com
Thx
Jo
Hi there! I've been calling and asking about the pricing of this optional security portal for the RV340W. No one has given me pricing nor a way for me to pay for it and install the license. Please help! Thanks!
Martin Aleksandrov
Hello Angel,
Thank you for reaching out to us.
We sell 100% through distribution so you have to either contact your local Cisco partner/reseller or optionally purchase the security license (LS-RV34X-SEC-1YR=) through e-commerce like CDW. For example, the license is available at:
https://www.cdw.com/product/cisco-rv-security-subscription-license-1-year-1-license/4556241
and
https://www.provantage.com/cisco-systems-ls-rv34x-sec-1yr~7CSC8MCA.htm
You will need to register a Smart Account to manage and use your security license for the RV34x. Please follow below two guidances in order to register for Smart Account and then register a Smart Software License on your RV:
https://www.cisco.com/c/en/us/support/docs/smb/cloud-and-systems-management/network-automation-and-management/smb5489-how-to-request-a-smart-account.html
https://www.cisco.com/c/en/us/support/docs/smb/routers/cisco-rv-series-small-business-routers/smb5540-register-a-smart-software-license-on-an-rv34x-series-router.html
Martin
EvanC75
With all due respect, the performance numbers listed above are not accurate.  On the RV345, with Antivirus enabled, HTTP throughput is greatly reduced to roughly 150 Mbps, and that is with logging off.  So the 980 Mbps listed is false.
Additionally, with firewall only mode, the throughput never gets above 650 Mbps.  My old router pulled over 800 Mbps testing from the same server so I know it is not my Internet connection or my computer.
If you are certain that 980 Mbps is possible, I would like an explanation on how to achieve this on my setup.
isove70954
Anyway will be a nice and good product for you cisco guys , but for me as a home user its the biggest "tzeapa" I got in my life
2weeks to activate the smart account with tones of emails and diff ppl
send emails to ask about the license that I need to activate a simple web filter , and nobody care !
I search with google where I can buy this license and I found some websites in US but not in EU  or in Romania where Im from
so An expensive hardware with low specs in my opinion , with some futures disabled , with a expensive fee /year
Want say more .... but its a crap
marsam
Hi Jo,
This article has been helpful to at least steer me in the right direction. I do have the RV340 and have watched most of the training videos made available from Cisco. I have one issue which simply revolves around resolving my fqdn which is configured in my Rv340. I have the proper certs, the system (as far as I've tested) is configured correctly but will not resolve with the fqdn that I've configured it with. I'm using AnyConnect to connect from client to site and when I test connection, I get an "untrusted connection" confirming that its working but I want to ensure that my SSL cert uploaded to the device is trusted before the connection is made complete. I've been wrestling with this for months and trying to just get another pair of eyes on my RV340 console. Any assistance from a Cisco Engineer who knows the Rv340 would be of great assistance. I don't want to have to remove the Rv340 tool and find something else because cisco products are very reliable.
Thanks.
