<<< Back to SBCS Third Party Applications
www.allscripts.com/products/electronic-health-record/myway/
www.opentheredbox.com
The small office healthcare sector is a fast-paced industry, which Unified Communications have been largely underserved. Allscripts, the leader in Electronic Medical Records software (EMR), can be integrated into and Cisco IP Telephony infrastructure, using a mediation application from EXTENSION® that allows administrators to enable alerts, escalations and intelligent browsing, from IP phones and softphones.
Benefits of the Allscripts MyWay Solution:
- One integrated solution covering practice management, EMR, and claims management.
- One unified database that makes finding the information you need for clinical or business operations fast and effortless.
- Designed for smaller-sized physician practices.
- Designed for the unique working environments found in primary care specialties.
- Designed to give you a choice: select a hosted service to minimize the cost and effort of using advanced technology; pick the on-premise version to leverage your current IT infrastructure and in-house capabilities.
- Practice Management Schedule: allocate resources, pull reports, handle the demographic details that profile contact points, insurance coverage, pharmacies used, and link it all into your billing process.
- Electronic Medical Records Build: patient history, clinical charting, capture lab results, handle e-prescriptions, and eliminate the paper chase.
- Claims Management, for filing claims and receiving payments.
Contact Information:
Allscripts:
EXTENSION:
Holly Benac
EXTENSION INC. (EI)
Channel Manager/PR
6435 West Jefferson Blvd. #201
Fort Wayne, IN 46804
Direct 260-243-0947
IMPORTANT: Third party application support is from the application developer. Cisco support involves setup/integration with SBCS only.
