nmanglik
http://www.cisco.com/en/US/solutions/ns340/ns414/ns742/ns816/cisco_validated.html
The CUCC tool is available for both Windows and Mac version.
The companion guides could also be downloaded from the same link.
The following guide provides the provisioning UCM using CUCC tool and provisioning Unity Connection using native interface.
Telephony Using Cisco UCM Technology Design Guide
a.gooding
Level 5
Level 5
Hi there
Is this still a tool being used? I was informed it supports only up to 10.0
Can you advise?
Thanks much
Randle Rivers
Tried out prime provisioning and wasnt very happy with it. seems like we took a good thing and over complicated it. Can we expect this tool to be continued for newer releases?
edit:
is it even available anymore?
Glenn Martin
Hello, Do you have a specific question regarding this product? If so, please open a discussion and post your question in the appropriate community. The Engineers don't look here for questions and they can't see them.
