The SPA9000 Analog IP PBX solution consist of a new configuration option which allows the SPA9000 to serve a Small Business with up to 18 Analog Phones, but using all benefits the benefits of VoIP. It is an Easy to deploy and affordable solution with a standard PBX feature set. It is designed for those Small Businesses with a reduced budget requiring basic telephony features, willing to use the savings of VoIP or to replace the cost of individual land lines with a VoIP-based affordable solution.
Download the new SPA9000 Analog Phone PBX Setup Wizard v1.0 and the related Application Note: SPA9000 Analog Phone IP PBX Configuration and start deploying it!
Main characteristics:
- SIP trunking-based solution, allowing the Small Business to obtain of the benefits of VoIP
- IP PBX (SPA9000) plus ATA (SPA8000) solution, supporting up to 18 Analog Phones
- Easy to install & Configure: New SPA9000 Analog IP PBX Setup Wizard drives the partners to perform installation and configuration of the system in minutes. SPA8000 support of RJ-21 TELCO connectors easy the connection between the system and the analog phones. No requirement for LAN switch
- Affordable solution: Estimated 80 USD per user*
Main Features:
- External calls via SIP trunk (3 accounts - 1 general, 1 VIP, 1 Fax)
- Incoming call handling: Autoattendant (virtual assistant) or 1 Hunt group
- Localizable autoattendant via Setup Wizard
- Call Control: Extension to extension dialing, Call Forwarding (Unconditional, No Answer, Busy), Call Transfer (Attended and Blind), 3-way conferencing, Redial, Call back, Do Not Disturb, Call Waiting, Speed Dials,
- Caller ID
- Internal Music on Hold
- Fax Passthrough (G.711)
Requirements:
- SIP Trunking service with an Internet Telephony Service Provider
- Analog Phones (not included in the solution)
Downloads:
SPA9000 Analog Phone IPPBX Setup Wizard v1.0
* Estimated street price per user for an 8 user solution, not including the analog phones. This price is only an indication, it does not represent a commit or endorsement. Street price is determined by the reseller.
