While we trust each and every Partner uses some sort of site survey to enable their deployment process in a way that is comfortable for them, we would like to share what we would recommend be included on a typical UC500 site survey.   https://supportforums.cisco.com/docs/DOC-16634
Eivind Jonassen
Level 4
Level 4
Nice
Steven DiStefano
Its tomorrows webcast :-)  (Dec 10th for tardy readers)
dtbullock
This guide is really helpful, thanks.  If there is any area where I'd appreciate more direction, it's to do with product selection for security - for example, exactly what trade-offs are we making when choosing to use the UC5x0 vs the SR520 vs the SA500.  (Also, since of those options, only the SR520 has a built-in DSL modem, what Cisco modem-only bridge is available which will let an internal SA500 or UC5x0 make a PPP connection ... or do you recommend the competition for that?)
