on 01-14-2011 01:36 PM
Working on a SPA IP phone can be frustrating if you do not have the interactive voice response [IVR] options available.
Don't forget that you can access the phone's help menu if you prefer to navigate without using IVR codes.
Function | Code |
Access IVR | **** |
Announce WAN IP address | 110 |
Control WAN port admin web server [1 to enable, 0 disable] | 7932 |
Reset to ITSP defaults | 877778 |
Factory reset | 73738 [R-E-S-E-T] |
Exit IVR | 3948 [E-X-I-T] |
Announce DHCP | 100 |
Enable DHCP [0 for DHCP, 1 for static IP, 3 for PPPoE] | 101 |
Set WAN port static IP address [* for period, disable DHCP first] | 111 |
Announce WAN netmask | 120 |
Set WAN netmask [* for period, disable DHCP first] | 121 |
Announce WAN gateway IP address [* for period, disable DHCP first] | 130 |
Set WAN gateway IP address [* for period, disable DHCP first] | 131 |
Announce MAC address | 140 |
Announce firmware version | 150 |
Announce primary DNS IP address | 160 |
Set primary DNS server IP address [* for period, disable DHCP first] | 161 |
Announce admin web server WAN port | 170 |
Reboot the device | 732668 [R-E-B-O-O-T] |
To input the password using the phone keypad, the following translation convention applies:
· A, B, C, a, b, c—press 2
· D, E, F, d, e, f—press 3
· G, H, I, g, h, i—press 4
· J, K, L, j, k, l— press 5
· M, N, O, m, n, o—press 6
· P, Q, R, S, p, q, r, s—press 7
· T, U, V, t, u, v—press 8
· W, X, Y, Z, w, x, y, z—press 9
· All other characters in the Administrator account password, press 0
<end>
I would like to know the ivr code to set and announce the vlan id for the ip phone spa501g as it does not offer help button 9.
Hello!
I am trying to configure mi IP Phone, but when I go into the web page, I do not have the admin login option...do you know why?
You should start discussion for questions like it. What's the value of [ Info ] tab, Product Information paragraph, Customization variable ? If you see other value than "Open" here, then you have OEM / customized unit with restricted access. Return it to seller unless it is intentional.
Note 7932 seems to be R-W-E-B (Remote Web)
When entering a password on the keypad of a SPA301 phone, how are numbers entered?
Are they the first character in the sequence, followed by upper case letters?
Or at the end of that sequence?
Or not at all, so zero is substituted for the specific number?
I have a SPA301 that is asking for the admin password when I press 9 to get to the IVR menu to reset it. It's brand new in the box and I am provisioning it for use on my own in-house system, this is not connected in any way to a VoIP service provider. It started out with factory defaults, then I loaded a provisioning file that I have modified, and now I want to test by restarting clean from factory settings.
Thanks.
