Patrick Born
Q:When busy on a call and someone uses intercom, page, or Push to Talk [PTT] my conversation is put on hold for the duration of the intrusive message. How can I change this behavior?
A:Modify the Auto Answer Page parameter with the Web-UI, phone's config file, or temporarily using the phone's interface.
NOTE: Configuring this to off, causes the phone to not auto-answer any intercom, page, or PTT calls, even when the phone is idle.
[Thanks for correction Adam]
  • Web-UI:
     User tab > Auto Answer Page: off
  • Config file:
      <Auto_Answer_Page ua="na">No</Auto_Answer_Page>
  • Phone interface:
               Setup Button > Preferences > Auto Answer Page: off
<end>
adam.baird
Please note that this setting turns off auto-answer in all cases, not just when there is an active line as the answer appears to suggest.
Patrick Born
Thanks Adam, I've updated the doc to reflect your input.
allcom-lika
Community Member
Hello and soz to bring back such an old post but i have a problem with the Auto Answer to headset.. Even if in the past i have managed to use it successfully with spa 303 firmware version 7.5.1a, now on every new spa not been able to use Auto Answer to headset.I have try even with the latest firmware version without success. Any help on this?
gurusol.system
Hello!
But what could be the reason that the phone did not automatically answer the call?
auto-on
