juliu2
Configure Link Aggregation wieh LACP enabled between Catalyst and 300 Serires switches. Version 2.0 correct some typos, and Add PAgP as Cisco proprietary statement.
jialbert
Sx300/500 Inter-connect with Catalyst
LAG/LACP example
[Catalyst]
Interface rang f0/11 -12
Channel-protocol lacp
Channel-group 1 mode active
[Sx300/500]
SG300(config-if-range)#channel-group 1 mode
  on                   Add port without LACP
  auto                 Add port with LACP
SG300(config)#Port-Channel load-balance
  src-dst-mac-ip       Port channel load balancing is based on source and destination of MAC and IP addresses.
  src-dst-mac          Port channel load balancing is based on source and destination MAC address. [Default]
[Sx300/500]
SG300#sh cdp nei
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
                  S - Switch, H - Host, I - IGMP, r - Repeater, P - VoIP Phone
                  M - Remotely-Managed Device, C - CAST Phone Port,
                  W - Two-Port MAC Relay
    Device ID       Local      Adv  Time To Capability   Platform     Port ID                    Interface  Ver. Live
       SW3             gi7      2     168     R S I    cisco WS-C3560-12P C-S       FastEthernet0/12
       SW3             gi8      2     168     R S I    cisco WS-C3560-12P C-S       FastEthernet0/11
SG300(config-if-range)#do sh int po 1
Load balancing: src-dst-mac.
Gathering information...
Channel  Ports
Po1      Active: gi7-8
SG300#show lacp Port-Channel 1
Port-Channel Po1
       Port Type Gigabit Ethernet
       Attached Lag id:
       Actor
               System Priority:32769
               MAC Address:    64:d8:14:5d:14:13
               Admin Key:      1000
               Oper Key:       1000
       Partner
               System Priority:32768
               MAC Address:    00:23:ac:c0:ac:00
               Oper Key:       1
SG300#show lacp gi 7
gi7 LACP parameters:
      Actor
              system priority:       32769
              system mac addr:       64:d8:14:5d:14:13
              port Admin key:        1000
              port Oper key:         1000
              port Oper number:      55
              port Admin priority:   1
              port Oper priority:    1
              port Admin timeout:    LONG
              port Oper timeout:     LONG
              LACP Activity:         ACTIVE
              Aggregation:           AGGREGATABLE
              synchronization:       TRUE
              collecting:            TRUE
              distributing:          TRUE
              expired:               FALSE
      Partner
              system priority:       32768
              system mac addr:       00:23:ac:c0:ac:00
              port Admin key:        0
              port Oper key:         1
              port Oper number:      269
              port Admin priority:   0
              port Oper priority:    32768
              collecting:            TRUE
              distributing:          TRUE
              expired:               FALSE
gi7 LACP statistics:
      LACP Pdus sent:                242
      LACP Pdus received:            217
gi7 LACP Protocol State:
      LACP State Machines:
              Receive FSM:           Current State
              Mux FSM:               Collecting Distributing State
              Periodic Tx FSM:       Slow Periodic State
      Control Variables:
              BEGIN:                 FALSE
              LACP_Enabled:          TRUE
              Ready_N:               FALSE
              Selected:              SELECTED
              Port_moved:            FALSE
              NNT:                   FALSE
              Port_enabled:          TRUE
      Timer counters:
              periodic tx timer:     26
              current while timer:   88
              wait while timer:      0
SG300#show lacp gi 8
gi8 LACP parameters:
      Actor
              port Oper key:         1000
              port Oper number:      56
              collecting:            TRUE
              distributing:          TRUE
              expired:               FALSE
      Partner
              port Admin key:        0
              port Oper key:         1
              port Oper number:      268
              collecting:            TRUE
              distributing:          TRUE
              expired:               FALSE
gi8 LACP statistics:
      LACP Pdus sent:                204
      LACP Pdus received:            188
gi8 LACP Protocol State:
      Control Variables:
              BEGIN:                 FALSE
              LACP_Enabled:          TRUE
              Ready_N:               FALSE
              Selected:              SELECTED
              Port_moved:            FALSE
              NNT:                   FALSE
              Port_enabled:          TRUE
      Timer counters:
              periodic tx timer:     14
              current while timer:   75
              wait while timer:      0
[Catalyst]
SW3(config-if)#do sh ether 1 sum
Flags:  D - down        P - bundled in port-channel
        I - stand-alone s - suspended
        H - Hot-standby (LACP only)
        R - Layer3      S - Layer2
        U - in use      f - failed to allocate aggregator
        M - not in use, minimum links not met
        u - unsuitable for bundling
        w - waiting to be aggregated
        d - default port
Number of channel-groups in use: 1
Number of aggregators:           1
Group  Port-channel  Protocol    Ports
1      Po1(SU)         LACP      Fa0/11(P)   Fa0/12(P)
SW3(config-if)#do sh ether 1 de
Group state = L2
Ports: 2   Maxports = 16
Port-channels: 1 Max Port-channels = 16
Protocol:   LACP
Minimum Links: 0
                Ports in the group:
Port: Fa0/11
Port state    = Up Mstr Assoc In-Bndl
Channel group = 1           Mode = Active          Gcchange = -
Port-channel  = Po1         GC   =   -             Pseudo port-channel = Po1
Port index    = 0           Load = 0x00            Protocol =   LACP
Flags:  S - Device is sending Slow LACPDUs   F - Device is sending fast LACPDUs.
        A - Device is in active mode.        P - Device is in passive mode.
Local information:
                            LACP port     Admin     Oper    Port        Port
Port      Flags   State     Priority      Key       Key     Number      State
Fa0/11    SA      bndl      32768         0x1       0x1     0x10C       0x3D
Partner's information:
Port      Flags   Priority  Dev ID          Age    key    Key    Number  State
Fa0/11    SA      1         64d8.145d.1413   9s    0x0    0x3E8  0x38    0x3D
Age of the port in the current state: 0d:00h:09m:07s
Port: Fa0/12
Local information:
Fa0/12    SA      bndl      32768         0x1       0x1     0x10D       0x3D
Fa0/12    SA      1         64d8.145d.1413   9s    0x0    0x3E8  0x37    0x3D
Age of the port in the current state: 0d:00h:09m:05s
                Port-channels in the group:
Port-channel: Po1    (Primary Aggregator)
Age of the Port-channel   = 0d:00h:09m:47s
Logical slot/port   = 2/1          Number of ports = 2
HotStandBy port = null
Port state          = Port-channel Ag-Inuse
Protocol            =   LACP
Port security       = Disabled
Ports in the Port-channel:
Index   Load   Port     EC state        No of bits
  0     00     Fa0/11   Active             0
  0     00     Fa0/12   Active             0
Time since last port bundled:    0d:00h:09m:05s    Fa0/12
Time since last port Un-bundled: 0d:00h:09m:47s    Fa0/12
SW3(config-if)#do sh lacp 1 nei
Flags:  S - Device is requesting Slow LACPDUs
        F - Device is requesting Fast LACPDUs
        A - Device is in Active mode       P - Device is in Passive mode
Channel group 1 neighbors
Fa0/11    SA      1         64d8.145d.1413  10s    0x0    0x3E8  0x38    0x3D
Fa0/12    SA      1         64d8.145d.1413  10s    0x0    0x3E8  0x37    0x3D
SW3(config-if)#do sh lacp 1 nei de
          Partner               Partner                     Partner
Port      System ID             Port Number     Age         Flags
Fa0/11    32769,64d8.145d.1413  0x38             15s        SA
          LACP Partner         Partner         Partner
          Port Priority        Oper Key        Port State
          1                    0x3E8           0x3D
          Port State Flags Decode:
          Activity:   Timeout:   Aggregation:   Synchronization:
          Active      Long       Yes            Yes
          Collecting:   Distributing:   Defaulted:   Expired:
          Yes           Yes             No           No
Fa0/12    32769,64d8.145d.1413  0x37             15s        SA
          1                    0x3E8           0x3D
          Active      Long       Yes            Yes
          Yes           Yes             No           No
GREAT
