pupandey
Community Manager
Community Manager
Wireless Access Points
Cisco Business Wireless Access Points (150AX)
Online Device Emulator (ver 10.0.2.0)
Cisco Business Wireless Access Points (140AC | 145AC | 240AC)
Online Device Emulator (ver 10.7.1.0)
Online Device Emulator (ver 10.6.1.0)
Online Device Emulator (ver 10.4.1.0)
Online Device Emulator (ver 10.3.1.0)
Online Device Emulator (ver 10.2.1.0)
Note: mobile browser support not available at this time.
WAP125 Wireless-AC Dual Band Desktop Access Point with PoE
Online Device Emulator (ver. 1.0.1.5)
Online Device Emulator (ver. 1.0.0.3)
  • Cost-Effective 802.11ac Wave 1 wireless technology
  • Single PoE (802.3af) Gigabit Ethernet port for simple installation and powering
  • intuitive web-based configuration wizard for deployment and setup in minutes
  • Support for Cisco FindIT Network management means easy management and control
  • Limited lifetime hardware warranty for peace of mind
_____________________________________
4 wap150-resized.jpgwww.cisco.com
WAP150 Wireless AC/N Dual Radio Access Point with PoE
Online Device Emulator (ver. 1.0.0.16)
  • Concurrent dual-band radio supports up to 1.2 Gbps for increase capacity and coverage
  • Gigabit Ethernet LAN interface with Power over Ethernet (PoE) for flexible installation
  • Single Point Setup requires no controller, for easy, cost-effective deployment of multiple access point
  • Sleek design with multiple internal antennas
  • Works right out of the box with easy installation and a simple web-based configuration and wizard
WAP361 Wireless AC/N Dual Radio Wall Plate Access Point
  • Concurrent dual-band radio support up to 867 Mbps on a 5.0-Ghz radio and 300 Mbps on a 2.4-Ghz radio
  • Supports 2x2 multiple-input multiple-output (MIMO) technology with two spatial streams for maximum performance on both 2.4- and 5.0-GHz radios
  • A 5-port Gigabit Ethernet LAN switch supports both PoE powered device (PD) and powered sourcing equipment (PSE) so that IP devices can be powered and the access point can be powered by the backbone switch
  • A captive portal helps enable highly secure guest access with customized roles and rights
  • Single Point Setup requires no controller for easy, cost-effective deployment of multiple access points
11 wap571-resize.jpgwww.cisco.com
WAP571 Wireless-AC/N Premium Dual Radio Access Point with POE
Online Device Emulator (ver. 1.1.0.3)
Online Device Emulator (ver. 1.0.0.14)
  • Dual-Radio 802.11ac connectivity with speed up to 1.9Gbps
  • Supports 3x3 multiple-input multiple-output (MIMO) technology with three spatial streams
  •  Dual Gigabit Ethernet LAN with Energy Efficient Ethernet and link aggregation support
  • Captive portal helps enable highly secure guest access with customized roles and rights
  •  Single Point Setup requires no controller, for easy, cost-effective deployment of multiple access points
  • Works right out of the box with easy installation and simple web-based configuration and wizard
12 wap571e-resized.jpgwww.cisco.com
WAP571E Wireless-AC/N Dual Radio Outdoor Access Point
  • Provides cost-effective 802.11ac outdoor connectivity with speed up to 1.9Gbps
  • Supports 3x3 multiple-input multiple-output (MIMO) technology with three spatial streams for maximum performance on both 2.4- and 5.0-GHz radios
  • Outdoor-rated IP66 enclosure designed for challenging outdoor environments such as rain and extreme temperatures, as well surge protection support
  • Sleek design with multiple internal antennas and a versatile mounting kit allows for installation on a pole or a wall
WAP581 Wireless-AC Dual Radio Wave 2 Access Point with 2.5GbE LAN
Online Device Emulator (ver. 1.0.1.3)
Online Device Emulator (ver. 1.0.0.4)
  • Provides cost-effective 802.11ac Wave 2 connectivity with speed up to 2.8 Gbps
  • Supports 4x4 multi-user multiple-input, multiple-output (MU-MIMO) technology on 5.0-Ghz radio and 3x3 MIMO technology on 2.4-Ghz radio for maxium performance
  • Supports Dual Gigabet Ethernet (2.5Ghz and 1G) LAN with Energy Effecient Ethernet and link Aggregation
  • Supports both Power over Ethernet (PoE) and AC Power with external power adapter
  • Offers captive portal that enables highly secure guest access with customized roles and rights
  • Offers Single Point Setup which requires no controller, for easy, cost-effective deployment of multiple access points
Learn more about Cisco Small Business Wireless Access Points
Great. Thanks for sharing
ashish.kushwaha
thanks for sharing this good stuff. it is excellent way to learn.
nbutlev
Hi there,
Also check these emulators:
CBW AC v 10.1.7
https://www.cisco.com/web/fw/tools/cisco-business/emulators/wireless/10-7-1-0/screens/dashboard.html#/MainDashboard
CBW AX  v 10.0.20.0
