Difficulty connecting SG500-28 L3 switch to a Draytek Router
chris-osborne
Hi All,
I'm really struggling with this one. I have an SG 500-28 L3 switch with a working trunk link to two other L2 switches. I am trying to allow hosts in the VLANS to access the outside world.. the L3 switch is connected to a Draytek router. I have assigned an IP address to one of the ports and have set routing in both directions from L3 to Router. I can ping from the L3 switch to the router and from the router to the L3 switch, but no hosts in any VLAN can ping further than the IP interface 192.168.254.253. Can anyone help with this? Is there something specific to this switch I am missing? IP routing is enabled on the L3 switch.
The L3 config is here:
switch8abb2b
v1.2.7.76 / R750_NIK_1_2_584_002
CLI v1.0
file SSD indicator encrypted
ssd-control-start
ssd config
ssd file passphrase control unrestricted
no ssd file integrity control
ssd-control-end cb0a3fdb1f3a1af4e4430033719968c0
vlan database
vlan 10,20,30,100
exit
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
bonjour interface range vlan 1
hostname switch8abb2b
username cisco password encrypted 0c4d0931711a0e9cb22337c1adbe39091ad15a73 privilege 15
interface vlan 1
ip address 192.168.1.230 255.255.255.0
no ip address dhcp
interface vlan 10
name SERVERS
ip address 10.0.10.254 255.255.255.0
interface vlan 20
name WARDS
ip address 10.0.20.254 255.255.255.0
interface vlan 30
name LAB
ip address 10.0.30.254 255.255.255.0
interface vlan 100
name ITECH
ip address 192.168.12.254 255.255.255.0
interface gigabitethernet1/1/1
switchport trunk allowed vlan add 10,20,30,100
switchport default-vlan tagged
interface gigabitethernet1/1/24
ip address 192.168.254.253 255.255.255.0
ip route 0.0.0.0 0.0.0.0 192.168.254.254
The draytek routing table is here:
Key: C - connected, S - static, R - RIP, * - default, ~ - private
*            0.0.0.0/ 0.0.0.0          via 172.16.0.1        WAN2
S~          10.0.0.0/ 255.255.0.0      via 192.168.254.253   LAN1
S~      192.168.12.0/ 255.255.255.0    via 192.168.254.253   LAN1
S~       192.168.1.0/ 255.255.255.0    via 192.168.254.253   LAN1
C~     192.168.254.0/ 255.255.255.0    directly connected    LAN1
C         172.16.0.0/ 255.255.0.0      directly connected    WAN2
I am also getting this error periodically on the L3 switch. Not sure if it is related to the problem.
switch8abb2b#19-Jul-2012 18:37:27 %CDP-W-NATIVE_VLAN_MISMATCH: Native VLAN mismatch detected on interface gi1/1/1.
Any help would be greatly appreciated!
Chris
Hi Chris, the problem would appear to be the router. It either doesn't support dot1q trunk/sub interface or you're missing static routes pointing back to the SVI of the switch.
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
chris-osborne
I should just add that traffic flows between internal VLANs without a problem.
Chris
-Tom
Hi Tom thanks for your response. The problem is sorted now, I needed to put
interface gigabitethernet1/1/24 into an SVI with an IP address as the switch did not support routed ports.
Many thanks,
Chris
