PXE boot SG500-28 with LACP configured
kionysus
I've got a SG500-28 that I'm trying to create a dynamic LACP bundle but still have it be able to PXE boot on a primary interface without manual intervention. I've discovered that the following configuration works, as long as I physically disconnect the second (1/20) interface so that the primary(1/8) is the only one with link during the PXE process. The biggest issue from what I can tell is there is no way to tell the second (1/20) interface to be passive. This is covered on pages 192-193 of this guide https://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/Sx500/administration_guide/Cisco_500Sx_v1_4_AG.pdf but it doesn't appear to work as designed or I'm completely missing something.
interface gigabitethernet1/8
 flowcontrol auto
 negotiation preferred master
 description "Port 1"
 lacp timeout short
 spanning-tree portfast
 channel-group 8 mode auto
 no macro auto smartport
interface gigabitethernet1/20
 flowcontrol auto
 description "Port 2"
 lacp timeout short
 no spanning-tree portfast
interface Port-channel8
 flowcontrol auto
 description "Port-Channel"
 switchport trunk allowed vlan add 732
 switchport trunk native vlan 70
5 Replies 5
Sujoy Paria
Please change the LACP port priority to 2 for the second interface (1/20) and check the status once (the default priority is 1). I think you want to achieve the below mentioned output (please check the partner section output for the port gi1/1/20)…
switchc6f8a9#show lacp parameters gi1/1/8
gi1/1/8 LACP parameters:
      Actor
              system priority:       1
              system mac addr:       00:8e:73:c6:f8:a9
              port Admin key:        1000
              port Oper key:         1000
              port Oper number:      56
              port Admin priority:   1
              port Oper priority:    1
              port Admin timeout:    LONG
              port Oper timeout:     LONG
              LACP Activity:         ACTIVE
              Aggregation:           AGGREGATABLE
              synchronization:       TRUE
              collecting:            TRUE
              distributing:          TRUE
              expired:               FALSE
      Partner
              system priority:       1
              system mac addr:       20:37:06:33:ee:6f
              port Admin key:        0
              port Oper key:         1000
              port Admin priority:   0
              collecting:            TRUE
              distributing:          TRUE
              expired:               FALSE
switchc6f8a9#show lacp parameters gi1/1/20
gi1/1/20 LACP parameters:
      Actor
              system priority:       1
              port Oper key:         1000
              port Oper number:      68
              port Admin priority:   2
              port Oper priority:    2
              synchronization:       FALSE
              collecting:            FALSE
              distributing:          FALSE
              expired:               FALSE
      Partner
              system priority:       0
              system mac addr:       00:00:00:00:00:00
              port Admin key:        0
              port Oper key:         0
              port Oper number:      0
              port Oper priority:    0
              LACP Activity:         PASSIVE
              collecting:            FALSE
              distributing:          FALSE
              expired:               FALSE
switchc6f8a9#
And make sure the switch firmware is latest 1.4.10.6.
switchc6f8a9#show version
       Unit             SW version         Boot version         HW version
         1               1.4.10.6            1.4.0.02               V03
switchc6f8a9#show system
Unit          Type
 1        SG500-28MPP
Unit   FAN
       Status
 1        OK
Unit   Temperature (Celsius)   Temperature Sensor Status
 1              28                        OK
Unit     Up time
 1     00,00:31:23
switchc6f8a9#s
Note: Please take a configuration back-up (working condition) from the mentioned switches before changing any configuration on the switch.
Please check the attached snapshot as well.
Sorry for the late reply. That didn't seem to do the trick. It appears to still be creating the PortChannel on the switch side and PXE never gets an offer from the DHCP server for the NIC attached to 1/8. If I unplug port 1/20's cable it works. Does my spanning-tree mismatch have anything to do with this?
#show running-config interface gigabitethernet1/8
flowcontrol auto
lacp timeout short
#show running-config interface gigabitethernet1/20
flowcontrol auto
lacp timeout short
lacp port-priority 2
#show running-config int Port-Channel8
flowcontrol auto
The following is seen in the buffer on the switch during the PXE boot process:
03-Nov-2019 15:30:44 %STP-W-PORTSTATUS: Po8: STP status Forwarding, aggregated (1)
03-Nov-2019 15:30:44 %LINK-I-Up: Po8, aggregated (1)
03-Nov-2019 15:32:46 %TRUNK-W-PORTREMOVED: Port gi1/8 removed from Po8
03-Nov-2019 15:32:46 %TRUNK-W-PORTREMOVED: Port gi1/20 removed from Po8
03-Nov-2019 15:32:47 %LINK-W-Down: Po8
03-Nov-2019 15:32:47 %LINK-W-Down: gi1/8
03-Nov-2019 15:32:47 %LINK-W-Down: gi1/20
03-Nov-2019 15:32:51 %LINK-I-Up: gi1/20
03-Nov-2019 15:32:51 %LINK-I-Up: gi1/8
03-Nov-2019 15:32:54 %LINK-W-Down: gi1/20, aggregated (1)
03-Nov-2019 15:32:54 %LINK-W-Down: gi1/8, aggregated (1)
03-Nov-2019 15:32:57 %LINK-I-Up: gi1/20, aggregated (1)
03-Nov-2019 15:32:57 %LINK-I-Up: gi1/8, aggregated (1)
03-Nov-2019 15:33:02 %TRUNK-I-PORTADDED: Port gi1/8 added to Po8
03-Nov-2019 15:33:02 %STP-W-PORTSTATUS: Po8: STP status Forwarding
03-Nov-2019 15:33:02 %LINK-I-Up: Po8
03-Nov-2019 15:33:18 %TRUNK-W-PORTREMOVED: Port gi1/8 removed from Po8
03-Nov-2019 15:33:18 %LINK-W-Down: gi1/20, aggregated (1)
03-Nov-2019 15:33:20 %LINK-I-Up: gi1/8, aggregated (1)
03-Nov-2019 15:33:20 %LINK-I-Up: gi1/20, aggregated (1)
03-Nov-2019 15:33:25 %TRUNK-I-PORTADDED: Port gi1/8 added to Po8, aggregated (1)
03-Nov-2019 15:33:25 %STP-W-PORTSTATUS: Po8: STP status Forwarding, aggregated (1)
03-Nov-2019 15:33:25 %LINK-I-Up: Po8, aggregated (1)
03-Nov-2019 15:33:45 %TRUNK-W-PORTREMOVED: Port gi1/8 removed from Po8, aggregated (1)
03-Nov-2019 15:33:45 %LINK-W-Down: gi1/8, aggregated (2)
03-Nov-2019 15:33:45 %LINK-W-Down: Po8, aggregated (2)
03-Nov-2019 15:33:47 %TRUNK-I-PORTADDED: Port gi1/20 added to Po8
03-Nov-2019 15:33:47 %STP-W-PORTSTATUS: Po8: STP status Forwarding, aggregated (1)
03-Nov-2019 15:33:47 %LINK-I-Up: Po8, aggregated (1)
03-Nov-2019 15:33:47 %LINK-I-Up: gi1/8, aggregated (1)
03-Nov-2019 15:34:22 %TRUNK-W-PORTREMOVED: Port gi1/20 removed from Po8
03-Nov-2019 15:34:22 %LINK-W-Down: gi1/20
gi1/8 LACP parameters:
Actor
system priority: 1
system mac addr: 00:8e:73:c2:f2:b4
port Admin key: 1007
port Oper key: 1007
port Admin timeout: SHORT
port Oper timeout: SHORT
collecting: TRUE
distributing: TRUE
expired: FALSE
Partner
system priority: 65535
system mac addr: a0:36:9f:85:65:b4
port Admin key: 0
port Oper key: 9
port Oper number: 1
port Oper priority: 255
collecting: TRUE
distributing: TRUE
expired: FALSE
gi1/20 LACP parameters:
Actor
system priority: 1
port Oper key: 1007
collecting: TRUE
distributing: TRUE
expired: FALSE
Partner
port Admin key: 0
port Oper key: 9
port Oper number: 2
collecting: TRUE
distributing: TRUE
expired: FALSE
Please use 'LACP Timeout' parameter as 'Long' instead of 'Short' on port 8 and 20, it seems that is creating the problem.
This never worked. I ended up buying a SG350X-24 and am running into the exact same issue. Can someone paste into here a vanilla config that shows how I can setup an LACP port channel that allows me to pxe boot off of the first interface in the LACP bundle? The ONLY way I can make this work is by physically disconnecting port 2...mind you admin down the second interface doesn't work.
