SG200-08 won't boot anymore
When I came back home today I saw that my SG200-08 switch did not look fine.
Basically, the system LED of the switch keeps blinking and end devices connected just don't have any network.
I tried to reset the switch with the "reset" button (with a paper clip) the system LED was orange during just a second and then continue to blink.
What is wrong with the switch?
Is there a way to flash a new firmware and/or to delete the configuration file?
Thank you for your help.
jasbryan
Level 6
Level 6
Guillaume Mazoyer,
If the system light is blinking green means it didn't pull a DHCP address from DHCP server.static assign your pc ip address to 192.168.1.20 255.255.255.0 and try and get into web gui @ 192.168.1.254. If this fails try hold the reset button again for about 30-45 seconds. If you still can't access the switch then call SBSC @ 1-866-606-1866 to open a support case.
Jasbryan
Holding the reset button a little more did the trick.
Thank you for quick answer.
