I'm having alot of trouble trying to connect more that one LAG between two SG300-52 switches.
Basically i have configured both switches with the same vlans. For 2 of the vlans i would like to connect them together between the two switches using LAG. Switch1 has Vlan 5 (ports 1-12) & Vlan 10 (Ports 25-36) with LAG configured on ports 1-2 and ports 25-26. I have setup the second switch identical to the first. But when i connect the LAG's there is no connectivty. If i disconnect one LAG the other starts working.
Can you only have i interconnect LAG between switches?
Your help is much appreciated.
