SG350-20 System Summary unresponsive with firmware release 2.5.7.85
vbec27001
SG350-20 "System Summary" unresponsive with firmware release 2.5.7.85 ( just "processing data" ).
I have tried after factory reset also , but the result is the same.
I had switch back to 2.5.5.47.
Any suggestions ?
BR, VB
balaji.bandi
is this after upgrade, if so raise an TAC case with SMB support.
BB
balaji.bandi
BB
I have the same problem since update to 2.5.7.85 on non PoE switch SG350-20, same fw works great on SG350-10P.
Now with 2.5.8.12 upgrade all is good, except that the update messed up with my password... I had to reset it through the serial console.
