Switch CISCO SG250-26 - DHCP Server - PPOE User
Dear all,
I just bought a CISCO SG250-26 26 Port Gigabit Smart Switch and I would like to know if it is possible to setup a DHCP Server on the Switch or do I have to by a router to set some static IP to my devices on the Network.
Another point is about the PPOE user, is it possible set it up on the Switch?
Thanks All the best
Martin Aleksandrov
The SG250 series do support DHCP client-only mode and DHCP relay. The DHCP server functionality is available on Sx350/550 series switches so you'll need a router or 350/550 model switch to utilize the DHCP server. On the other hand, PPPoE may be implemented on your Internet-facing gateway device like xDSL modem or router. Sx250/350/550 switches are not NAT devices, therefore, can't act as residential gateways for your internet connection.
Martin
balaji.bandi
You can setup a DHCP Server in the model of switch
https://www.youtube.com/watch?v=Rw7tI1tAhMo
here is admin guide :
https://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbss/sf_sg250/admin_guide/AG_Tesla_250.pdf
BB
Martin Aleksandrov
Martin
That's it, there is no DHCP Server on Switch SG 250
Thank you very much
