Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 3642 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 5326 Views
  • 1 replies
  • 16 Helpful votes
Saludos Estimad@s.Estoy buscando un equipo que soporte IP SLA para pequeñas empresas. Estoy mirando el CAT1000, sin embargo, no ubico información acerca del CAT1000 para el soporte de IP SLA. Qué opción me pueden recomendar CAT1000, CBS250, CBS350?. ...
ccz by Level 1
  • 1411 Views
  • 3 replies
Hi Everyone,This is the first time I have worked with the CBS350 switches.  We have been supplied both the 24 port model and also the 48 port PoE units (in the 4G variations).  The spec sheet says all these units are stackable and it should all be au...
Привет. Существует корневой SG350-10-sfp и SG300-10, подключенный к нему через модуль MGBLX1 SFP. Соединение стабильно, но происходит циклический перезапуск sg-300 в случайном временном порядке. SG-300 не пишет никаких явных ошибок о причине перезагр...
Hallo, folgende Warnmeldungen werden ausgegeben: siehe Log unten. Was genau bedeuten sie ? Wir haben das Problem, dasstrotz Bandbreite das Internet sehr langsam ist...Die angeschlossene Watchguard ist gecheckt und an ihr liegt es nicht."%NT_GREEN-W-E...
i want to list and show the VLAN-id and VLAN-name by api (json) from Cisco busniess Dashboard , how can i do thati found just put methode not getreferneces:https://developer.cisco.com/docs/business-dashboard/#!api-referenceput /v2/nodes/{nodeId}/conf...
Hi all, I'm new here so please be kind!Bought an SG350-10 switch recently to use in my home labI'm setting a static IP on the switch and all is working fine.. I've got this plugged into an older ASA5505 that has no DHCP configured on the port plugged...
Hi,My backbone switch is constantly producing traffic from switch itself to  224.0.0.251:5353 in every 5 seconds.I learned that it is bonjour traffic which i dont need.Therefore i globally disabled bonjour discovery from the switch but i couldnt stop...
akanarya by Level 1
  • 1385 Views
  • 4 replies
I tried Cisco Configuration Professional for Catalyst for the initial setup of a Cisco Catalyst 2960L-24TS-LL. I ended up falling back to the good old console and upgraded the software to c2960l-universalk9-mz.152-7.E. If I set authentication local f...
Dwokfur by Level 1
  • 2617 Views
  • 11 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
