CISCO WAP200 after reset will not accept default id/pswd
klp283301
   I had to reset the WAP200 wireless device expecting that it would then allow access using the default id/pswd of admin.  Unfortunately, I am not able to gain access to the setup GUI as it does not recognize the default id of admin and pswd of admin.  I reset the device twice with the same result.  The device warranty ran out in 2012 as it was purchased back in 2009.
Any pearls of wisdom so I can gain access?
Best Regards
Tom Watts
Hi Kevin, can you verify how you reset this unit? Hold the reset button in for like 35-40 seconds.
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
mpyhala
Level 7
Level 7
Kevin,
Is the AP plugged into your network or do you just have a PC plugged directly into it with a static IP? I would give the PC a static 192.168.1.200/24, no gateway. Reset as Tom suggested and then log in using admin/admin.
- Marty
