API Serial number to information
I would like to access at this API https://api.cisco.com/sn2info/v2/coverage/status/serial_numbers/
But I don't know how to. I have access to https://apiconsole.cisco.com/apps/myapps and know how to create token.
But I can't find which API is it. Or i'm going to the wrong way, I don't know...
Thanks a lot.
jofrumki
Hello @AntoninBRINES42572
For this type of API please direct your questions to supportapis-help@cisco.com
Thank you
Justin Sprake
This documentation a good resource to ensure you have completed the necessary on-boarding and access steps:
https://apiconsole.cisco.com/files/APIx_Platform_User_Guide.pdf
Since you may be able to generate an API token, you may already have access to the API console, the WADL for SN2Info is available here:
https://apiconsole.cisco.com/docs/read/external_apis/Serial_Number_to_Information_API_Version_2
Lastly, the actual URI for SN2Info is available here:
https://developer.cisco.com/docs/support-apis/#!serial-number-to-information/get-coverage-status-by-serial-numbers
Thanks for your reply.
But I cant still access to the apy. In 'Key' on apiconsole, I cant find the api sn2info. Is it here ? or else.
Antonin BRINES
I have this but cant 'Register', How to do that.
