apix onboarding/entitlement issue
rgkuhn
I was wondering if someone would be able to help me with the error i am having while trying to get data from the cisco apix endpoints.
One example endpoint is
https://apix.cisco.com/supporttools/eox/rest/5/EOXByProductID/5/A9K-MPA-2X40GE
I get a 403_DEVELOPER_INACTIVE message and i have been told it may be an issue with the account not being onboarded correctly in the backend maybe?
23 Replies 23
kaptanej
Hi ,
I am the in-charge of this post and will be assisting you shortly on the issue .
Please provide the following details so that we can troubleshoot on the issue :
  • Customer Name
  • Company Name
  • Customer CCO ID
  • Customer's Email address
  • Contract Number
Thanks & Regards,
Kapil Taneja
Hello Kapil,
I DM'd you with the information you requested.
Thanks.
Hi ,
Thank you for providing the information . Let us check the details and we will get back with an update.
Thanks & Regards,
Kapil Taneja
Hi Kapil,
I am able to generate token by using client id and client secret of our registered application, following the documentation. However when we attempt to access any endppoint using the generated token, we receive a 'Developer inactive' response.
Please suggest something on this.
pcampbell
Hi, don't want to hijack the thread but I'm having the same problem with the endpoint https://apix-test.cisco.com/commerce/ORDER/POE/v2/sync/checkOrderStatus.
Can I send you the details in a DM @kaptanej?
Hi ,
Sure, could you please provide me the information via private message.
Thanks and Regards,
Kapil Taneja
I have the same issues and sent a DM to @kaptanej on 5/10/2023.  Using the following: https://apix.cisco.com/supporttools/eox/rest/5/EOXBySerialNumber... and it is returning "Developer Inactive".
***UPDATE*** I got this to work! I was missing that the token generation URL had changed to https://id.cisco.com/oauth2/default/v1/token
See https://apiconsole.cisco.com/docs/read/overview/Migrating_Applications
Thanks!
Hi Thompl14,
Let us check the details and we will get back with an update shortly.
Thanks & Regards,
Kapil Taneja
good day
iam trying to access cisco software reserach api to check the recommened and suggested release
https://apix.cisco.com/software/suggestion/v2/suggestions/software/productIds/C9200-24P?pageIndex=1
i created application using service and client credentials
token is getting generated
but my response is
Developer inactive
angelest
Hi Kapil,
Are you the one also in charge to PSS API's?
I have issue with EOX API getting 504 Server Error: Gateway Timeout for url
'https://api.cisco.com/supporttools/eox/rest/5/EOXByDates/1/2023-01-01/2023-12-31?responseencoding=json'
As a PSS partner you are entitled to open a TAC case with Cisco. This community is for providing support to SNTC customers without a Smart Assist contract.
Please go to Support Case Manager (SCM)then provide the necessary information.
Thank you
angelest
Thanks. About to open a TAC case and suddenly its working again.
i face the same issue
developer inactive
i have dm ed the information
i could generate token, but it is not working
i changed api to apix as well
AnandChavan
I am facing the same issue. Token request is successful from https://id.cisco.com/oauth2/default/v1/token
But when I try querying the GetProduct API - https://apix.cisco.com/product/v1/information/product_ids/UBR10012,ASR1001
I get <h1>Developer Inactive</h1error.
How to resolve this issue? Any ideas
