Call manager is correctly discovered in CSPC but SNTC not showing any hw or sw info about the CM
LalitaK
Call manager is correctly discovered in CSPC but SNTC not showing any hw or sw info about the CM.
Cisco unity server and Presence server shows all the hardware and software information but the Call manager just shows the hostname and IP address in SNTC , may be due to that no phones are discovered on the portal
Hello Lalita,
It appears the call manager is being collected using SNMPv1.
Ideally you don’t want to be using SNMPv1, this normally leads to some features missing, in other words, SNMPv1 is more limited than the other 2 newer versions.
We would like you to remove SNMPv1 credential and use SNMPv2 to scan and rerun an inventory/upload.
Please give this a try, we can verify the results upon new upload.
Suchita
7 Replies 7
Suchita Shewale
Dear Lalita,
Can you please share the inventory name, IP address of Call Manager that has issue and also IP address of some phones that do not show up on the portal?
Suchita
Hi Suchita,
The inventory name is MR***, call manager IP address is 10.1*** and below are some IP phone details and model of the phone is 7945
10.1***
10.1***
10.1***
Appreciate your help!
Lalita
* Text has been masked to preserve data privacy.  Please provide sensitive information via private message.
Hello Lalita,
Thank you for the details.
It appears that the call manager is missing SnmpObjectID in collection, due to which portal did not profile the call manager.
I am checking with CSPC experts on what settings can be changed to collect the sysobjectid in this case, and will get back with the update at the earliest.
Suchita
Thank you Suchita
Awaiting your feedback!
Hello Lalita,
Suchita
Hi Sucitha,
Added the call manager using snmpv3 and now we are able to see the hw/sw details of call manager and also we are seeing all the phones in the portal.
Thank you so much!
Lalita
Hello Lalita,
Thank you for the update! Glad to know it worked :)
Suchita
